- 11 Sep 2013
Might as well stand by the roadside and see if we can hear the bike, then... This was about how hard it can be to hear a loud bike under fairly normal-ish driving conditions. This was basically how the Mrs drives when in a happy mood, music a bit loud, engine coming up to a shift-point (it's auto, so no real choice about that), windows up and driving through town areas.A merc probably isn't the best car for trying that, they're normally very well insulated from outside sound. Try it again in a ford fiesta or something more run of the mill and it might be a different story.
This is an old M-reg Elegance by the way, not the newer C-Class, so probably still not as insulated as modern cars.
That insulation is exactly why we chose that car (and because it is the only one my wife owns, but hey...). Besides, more and more cars are advertising how well insulated from outside noise they are, so if that is the way things are going...
You don't get to choose what you pass on the road, do you? Better to test the worse case circumstances than the easir ones, because it will be the ones who cannot hear who are more likely to be a problem.
Loud pipes might make some cars more aware of your presence. Others quite simply will not be able to hear you, so ride accordingly. Kinda the same as assuming you've been seen just because you have headlight, hi-viz and a white lid.loud pipes do make cars more aware of your presence.
HiYaAaaa!!!!
