Legend, thanks for this man. Just copped one!
...aand I just nabbed the last one!! Thanks v much for the heads up![]()
I had this metal taste in my mouth all the time when I vaped on kanthal but now I've swapped to 316l on a temp. controlled mod that's gone. I'm pretty sure it was the kanthal wire that caused it, i just can't think of anything else.Does anyone find going back to Kanthal from Titanium leaves you with a slight metallic tasting juice? I just find kanthal more metal tasting if that makes sense.
Looks like they will work but like UKDTweak says, Athena isn't a great mod. What do you mean by slipping cotton through the coil routine? If you're building your own coils that tank will be a step down, and £2.59 a coil too!
I'd consider the kanger subox mini, same amount, if not less, as what you're going to pay, and you get a better box, a good tank (so I hear), removable battery, up to 50W rather than 30, and an RBA base, should you decide to try your hand at coil building. Not to mention the coils are much more common so it's more likely your local vape shop will have some on hand if need be.
edit: If you are already building coils, the stuff posted above seems like the way to go. Based on the good reviews here I'll likely pick up an aromarizer when my DNA200 arrives, have a feeling the lemo won't handle much more than 40W with it's small juice channels and build deck.
I'm not really wanting to get into coil building, I don't trust my self to to d half decent job and don't paying a little for a new coil.
What I mean above is the NatureVape is just the small starter one I have, it comes with a premade coil that I just change the wick/ cotton on once a week, I find it handy, I'm kinda just wanting a step up in terms of setup, but not much more in maintenance..does that make sense?
I had the fluid on my chest and tight feeling teeth but I still smoke 2 or 3 normal's a day. I have found though that my nose is clearer and everything tastes better which is bliss now!
My only vaping gripe is the different juices. Some have the bad bits in them and some don't work with individual people. If more sellers did independent checks and displayed them to the public it would help some people have more confidence in vaping, it is after all the most fun way to give up smoking!![]()
Do you understand that Temp Protection should be reached almost immediately, like as in less than a second? That just indicates that the coil has reached your desired temp, not that there is a problem. Your wattage should be set high enough to reach your set temp very quickly, and low enough so that it does not grossly overshoot the set temp.
I'm going against the grain and say the d2 is not a good starter mod, I have one and love it, it's my everyday beater.. But it doesn't have step down so vaping on it can be over powering. Not an issue if you use mechs or dna30s.. Also thou I know many people who uses the on board charging.. It's a p4u and they don't have the best track history, so I charge my battery with an external charger.
Not really. I have a 60%VG and I believe the local B&M has a brand with 70%, but that's it. I haven't really started shopping for liquids online yet.Do most of you sub ohm vapers use high VG juices here?
My 0.4Ω Ti coil hits temperature far faster than the 0.2Ω Ni one, sure. Both manage it within about a second if I fire before dragging (so the airflow doesn't cool it back down). My preferred temp is around 280ºC, it seems.Another one for the Temp Control Users
Is this how Temp Protection works? Does your device do that and is he correct?
I set my power to max so it hits temp as fast as possible, then adjust my temp to taste.
It’s payday! Which means one thing…
So I have my eye on the Aromamizer (Struggling to find somewhere that has it in stock.)
Anything else people recommend? Not into my RDA’s and I have the Uwell crown.
Mod I think I am happy with at the moment.
You do realise that the 2 or 3 fags you have a day has way more diacetyl in them
than any juice. Thats not even mentioning all the other nasties in fags lol
