Tomb Raider Ultra Bench
He should have no problem with his CPU speed getting a good 1080p score either as this bench does not bottleneck that much. If you look at the 1080p score I posted earlier I managed 339fps with a CPU clockspeed of 4.0ghz.
I suspect he has not enabled SLI as his scores look about right for a single stock card.:)
65FPS for a Titan X at stock? My 290X managed 61FPS...
Am i missing something? :p
TitanXs are better overclockers than 290Xs and Quartz is running his @stock.
Your Haswell based CPU is more efficient than an ivy bridge 3770S.
You are also probably using better RAM with your 4790k as well.
Well, I triple-checked, and @thebennyboy is correct: I found I indeed had SLI disabled.
2x Titan X SLI Stock
i7-3770S Stock (3.1 GHz base)
358.50 drivers
1080p
4K
Now, if you'll excuse me, I have an appoinment with the Mess Webley. :)
Thought I would upload some R9 Nano benchmarks :)
4690k @ 4.4 Ghz, R9 Nano @ 1050 Mhz / 500 Mhz Drivers: 15.201 (I think? not to sure how AMD driver number works as I don't seem to have a single xx.xx number)
1080p
3440p
AMD Nano
15.9.1 Beta
1055/500
CPU: 6600k @ 4.5GHz
Min: 13.6
Max: 25.2
Average: 19.4
2160p
Min: 28
Max: 56
Average: 40.7
1440p
Nvidia 980Ti Hydro Copper @ 1378/1993
Intel 5930k @ 4.6GHz
Drivers: 358.50
2160p
Min: 18.8
Max: 34.9
AVG: 26.8
1440p
Min: 40.0
Max: 78.0
AVG: 58.0
1080p
Min: 64.0
Max: 118.0
AVG: 88.5
