So far it has gone very well. Got it setup quickly, windows 10 reinstalled and activated, and then moved on to testing all ports as I read about a possible USB issue - there is none on my side.
I then checked RAM speeds etc - all correct as I am not using XMP
CPU temps - idling around 27 degrees.
Overclocking - I have initially done 4.5ghz at 1.25v with a 1 hour prime burn - will mess with it more over the weekend.
So far very impressed, haven't tried the Wifi but I doubt I ever will.
I know but Im not too worried to be honest as X99 are enthusiast setups, so you will hear more noise on forums from end users.
The only thing that concerned me about this board was the OC socket frying chips but it seems to still be minimal noise.
If your bottom two USB ports work when booting then you're a big fat liar.
The bottom two ports on Asus Mobos NEVER work.
lol! tbh I haven't tried it but I can see you can set all ports enabled in the bios.
