yes please would be nice to see them.
the gtx970 is cooler and quieter than the 7950 even when it was stock
Any ideas on how to get the individual Firestrike test? Did you buy 3DMark?
I honestly cant remember Ive had the software that long I just install it when I done a fresh install.
I got into 5 figure score though after a moderate overclock
http://www.3dmark.com/fs/6393808
Run these settings on yours as i have basic and its all i can run (gyazo is a screenshot thingy, don't worry haha): https://gyazo.com/eb7771baed0e28f9e707b6c76d6c2e22Any ideas on how to get the individual Firestrike test? Did you buy 3DMark?
yea I was fairly chuffed with it. as you can see in the gpu info it is just a moderate OC no voltage increase and even in valley it made an improvement.Nice score and i can only get to a 5 figure when running both cards.
this is my exact thoughts on it.Go for the d15 and with the other £30, you could buy some better case fans.
If I go for air then I can get 2 really good fans mounted up front to get cool air in to the system which will benifit the Air cooler. then get a good 140mm fan on the rear for getting the hot air away from the cooler and out the back..
I also saw a thread on here where a boy fitted an intake to the roof at the front and this also gave him an improvement on temps with his air cooler.
Yeah air coolers love loads of air and yes your be better doing that.
For the rear fan make sur its a high cfm.
Yeah that will be good and do you know what fans you mite be getting yet.
Ive tried that. I get lower temps using it as an intake.hmm I think the top one may be best as an exhaust, that seems to be the standard config.
that would be my thoughts. or if I go with the phanteks ill do the same which Ive already got one sittingMatching fans to go with the d15 ?
I already have 1 of these
https://www.overclockers.co.uk/phanteks-ph-f140hp-140mm-fan-red-white-fg-012-pt.html
