Think these are the ones you need (from the Denis forum thread), unless anyone else knows better...
Quick google image search of both his processors CPU-Z screenshots show that they both support sse4.1.
Yes, possibly for the SSE3 one but would expect Crunch3r's SSE41 app to be faster for a processor with SSE4.1
sorry to be a pain...
what will I need for 9590 and 2450M?
am sure I have sorted my 5930k out by using avx2
I think you want the SSE41 version, I found this...I think I've resurrected the 64P cruncher, but want to see some WUs validate before I count any chickens .....
This has to run linux as I'm not rich enough for a Windows server version that recognises 4 CPUs. But currently each WU is going to take nearly 4 hours to complete. If it remains like that it's not going to be kept running, just too inefficient compared to the optimised Windows client.
Now I'm a real numpty when it comes to Linux, and have to be spoon fed explicit instructions.
Looking at the optimisation thread over on Denis there are a number of versions for Linux files available: http://denis.usj.es/denisathome/forum_thread.php?id=53&postid=550#550
Which do I need for the machine spec: http://denis.usj.es/denisathome/show_host_detail.php?hostid=47767 ?
I hope that install will be as simple as http://denis.usj.es/denisathome/forum_thread.php?id=53&postid=498#498 of things will go FUBAR very very quickly.
Thanks all. I think I've got the optimised thingy loaded. Certainly the expected ruin time dropped but it's still over an hour per WU. On the other hand 64 WUs an hour is probably quite nice
I'll let it run just a few WUs over night and then check how many validate before going any further.
Yay.
I'll fire it up properly tonight ready for the challenge thingy. That's assuming there are WUs left to be done. Looking at Denis' server status the waiting WU numbers have dropped dramatically in 24 hours.
@Boycie
I've noticed that your v3 Xeon runtimes are considerably more than mine and Colin's. I don't know if there are any other issues but I would definitely recommend running the AVX2 optisimed app if you haven't done so already. Goes for anyone else with an haswell or skylark CPU.
Download:
http://optos.sesef.pl/denis or https://dl.dropboxusercontent.com/u/1452459/denis/denis1.6.1_avx2.zip
Looking very goodAm I looking good? I've been travelling almost everyday the last week so i've not been able to tend the flock. I'm still only getting ~70% CPU utilisation in task manager but there are definitely 40 threads per machine running
B
B
