Do you guys recommend removing the fps cap and if so, how do you go about it?
Personally, I haven't found it to be all that worth it, though that may be something to do with recording game play. If you do remove it, I'd set a frame rate limit otherwise it can screw around with the game, e.g. animations operating much faster. You can use the following to have a tinker with, and I think Afterburner can set a precise limit on what you want that to be, such as 65 / 70 / 75.
http://www.nexusmods.com/fallout4/mods/102/?
Out of interest, does anyone know why the FO4 options control panel changes the choices you make. For instance, I set everything to ultra, yet when I check things later one or two of the settings have dropped down to high or medium (namely godrays and lighting)?
