Can't you just pop into a shop?
Ive enabled on screen buttons. Its nice that you can also keep the hardware button enabled with different actions, very handy.
I sort of want to put a sticker on the on screen buttons - don't want to take up realestate with the onscreen ones, but the off screen are impossible to see...
One of the most annoying things about the phone
Buttons dont light up, meaning quite often you either press too high up, or too low down
The power button should be above the volume buttons
Software bugs
Guess you can't complain for £200
Really can't see the issue here. Right, centre, left. I've not managed to miss any of the buttons once.
There is one pre-applied
It's not decent though. It doesn't quite fit right, and I'm not convinced any would as the edge of the screen slopes slightly.
It's Gorilla Glass, just rock it naked.
