FX-8350 Overclock
27 Mar 2010
I think i see that thread aswell, i will have a look for it aswell.
I have the ud3p with my 8350 @4.8ghz but i had to put a fan on the front and back on the vrms as i never liked them going pass 80c.
With that 78lmt, there someone on ocn who hit 5ghz stable without throttling.
Yeah I was the first then another guy called jason387.
I just checked you previous thread Humax, it does seem apm has been left out as I suspected. It's a bummer as the 970a is a much better board and was cheaper.
29 Aug 2010
Cornwall
Could it be a Fan problem ?
Na, if there was an issue with the fan the metal of the heatsink would be really hot as the fan isn't cooling it. If your CPU is getting to 70ºC but the metal is cold then it seems like poor contact.
There's not like a bit of clear plastic on the bottom of the 212+ you need to remove or something is there?
