- 29 Aug 2010
- Cornwall
Would it be madness to get this monitor with a 980ti?
Depends really. If you're ever planning or open to getting an AMD card (while you have this monitor) then why not?
It's decent enough for now and then you get Freesync if you move to AMD.
If you're not planning to use the Freesync then it's probably no better or worse than a number of other similar monitors.
I'm regretting my decision right now, but at least part of that is because of the fault mine's developed. Now I'm at the mercy of BenQ's RMA service I guess. Guess I could've used the etailers return service but I'm never confident enough they'll notice the error (it's not glaringly obvious, but once you've seen it or it's been pointed out...).
