- 18 Oct 2002
I know its 1080p as i had a meeting a few months ago about the system. Sky engineers will have the system fitted at their homes over the next couple of months ahead of the public.
Sky Q does look pretty goodBut i suspect the costs will, initially, be pretty ridiculous especially for the full monty, ie - Sky Q Silver box etc.
How do you envision that working?
Maybe i'm barking up the wrong tree but in my head, i don't see how you could achieve that without introducing (more) P2P connections which would in turn increase load on the network
Similarly, i can't see how you could easily move DVR functionality away from homes as you either (essentially) move the DVR/STB to a hubsite/hubend, which sounds a little pointless to me; or, VM changes to an on-demand type service for DVR functionality but then surely they'd have to store every programme broadcasted which i imagine would be a world of hurt and no doubt stupidly costly
I don't doubt they'll move to IPTV but it's easier and simpler to have the DVR portion within the STB/home.
But we don't make any TV at 1080p
Is the 4k capability definitely being fed from the dish rather than from the broadband input?
I just want to know the cost of a new Sky box and Sky Hub and will Sky existing customers get a discount or yet again will sky get greedy and ask for more money on top what we are paying
As great as it looks I wish they'd just sort out providing Fibre to the UK. I have to have Virgin because there is no BT line and that's on a new build on a brand new estate. Especially if (the tinterweb) talk is true that you'd need a sky hub for the mini box.
Love Sky as it is far better than VM Tv and is so more user friendly but I couldn't get by on 1-3mbps 'broadband'.
It's not difficult to see what the attraction is to Kodi etc IF the tinterweb talk is correct.
That not good..The Sky Q Mini is essentially your multi-screen box. It doesn't have a hard drive and it doesn't connect to the satellite dish. Instead the Sky Q Mini streams content from either the Sky Q or Sky Q Silver boxes. You can use it to record content on the main box and any recordings can be viewed on either box.
That not good..
As it going only be 1TB Sky Q or 2TB Sky Q Silver of harddrive of space to share between the main box and the multi screen box/boxes..
(but it will be good that you will be able to watch saved stuff on any box)
Where having multi room with my two 2TB sky boxes would total 4TB of space
Have Sky worked out yet how they are going to upgrade communal systems? Presumably this needs a multiswitch upgrade at least - does it maintain backwards compatibility?
Or do the Q boxes just fall back to regular two-feed operation if they are connected to a 'normal' feed? Most management companies who handle the maintenance of communal TV systems don't have a clue what they are doing or how to spot a cowboy so I can see this technology staying out of apartments for a while.
That not good..
It's perfect IMHO...
I don't want recordings on different boxes around the house. I want a seemless (central) source, which, no matter where I've pressed record in the house, I can access from anywhere/everywhere else in the house.
We have 1 TB drive and mainly record HD sources and IMHO that's a fair lump of space. If that was doubled (to 2TB) I'd be more than happy with that.
IMHO SkyQ is the logical approach for many households, unless you have distinctly different users, so you what separate boxes. (ie: A kids box in the playroom, and a parents in the lounge).
Well I can only comment for myself, where my existing 1TB limit works fine. I typically sit at aound 15-25% free. If I had more space, I'd just be building up more stuff I'll never watch and be delaing the inevitable clear upYou may well be happy but for a central storage 1-2tb is a complete joke Sly are like MS with XBone they will bring out another one which is larger storage and few other tweaks so they can charge people again and always behind in tech world.
They're homeplug I believe. All built in... With a possible option of wireless as a fallback?I think people have forgotten one really important thing these devices will all be wireless this could be a nightmare.
So given a bit of 4K recording, for me at least, 2TB would be fine.
You never know, maybe they'll let you plug in a passport USB drive and use that too as additional space (like the XBox)? But I suspect not personally.
I believe the Sky Q boxes have ethernet connectors too, so it may well be if you have a lan in the rooms, they can make use of that superior network too?
If you intend to watch 4K TV then I would not recommend going for the Sky Q box as that will only work with up to HD broadcasts.
