The Elder Scrolls V: Skyrim - MODS & TWEAKS
I've started replaying and installed lots of mods :cool:
Only serious problem I've had was last night when I tried the "Breezehome FullyUpgradable" which redoes er...Breezehome. Seemed to work at first then all hell broke out, CTD all over the shop when zoning.:eek: Even previous saves which worked (with the mod) started to CTD. Had to go back to a safe save.
Anyone tried it and had problems?
Dont use both. Infact. Dont even touch Steam workshop. Take a screenshot of your load order, we can help.
If I were you I'd start using Mod Organiser from the get-go and forget about NMM. It's a powerful tool, especially when combined with the LOOT load order utility.
I'm currently playing Skyrim using Mod Organiser and Fallout New Vegas with NMM and if it wasn't for the fact that I've almost consumed every available mod going with FNV I'd completely remove NMM and never use again.
I uninstalled it to make room for Fallout 4 but looks like I might have just enough room to install it again. I'll give it another go at some point without and without NMM and see how it goes. Thanks for everyone's help so far :)
Wow finally got the mouse working (mostly) ok - could never play at a capped 60fps before G-SYNC and the mouse is just horrid with how broken it is at higher framerates.
60fps capped with G-SYNC using a Zowie FK at 450dps/1:1 mapping in windows plus MarkC mousefix and using:
fMouseHeadingSensitivity=0.0250
fMouseHeadingYScale=0.0375
fMouseHeadingXScale=0.05
bMouseAcceleration=0
Finally got something that feels natural, no stutter, not shooting all over the place as the framerate changes, etc. though might need a bit more tweaking to tie up X/Y axis sensitivity.
Might try and give the game another run through though hate how broken the UI is and can't be bothered with external programs like SKSE to use skyui.
EDIT: Oh and are there any actual good natural looking texture mods? I've got some "HD" packs that are lightly touched original HD textures but last time I tried the 2K/4K type packs I really disliked the amount of overly heavy embossing/sharpening used and how often a nice high resolution texture had been used but sat awkwardly on the geometry just looking naff.
So I gave in, installed SKSE and SkyUI - wow does it transform the game - especially being able to map favourites to something useful - though kind of clunky having to set it all up again and again as you get new gear, etc. but the combat is 100x better when you can quickly swap between offensive and defensive powers/weapons, utilise a selection of potions or scrolls fluidly in the middle of a fight, etc.
EDIT: Then ran into a situation where the enemy was highly resistant to all my preset loadouts lol...
Look in the ini files or config files for the ENB and search for any dof settings that are disabled, FALSE or 0.
I would help you more, but it's bed for me now :)
Yea, I chose full graphics mode. Every mention of "depthoffield" in the ini files is set to true or 1. There's no mention of it in skyrim.ini
Here's my ini files just in case any of you guys see anything I've missed (it's got to be a rogue setting somewhere).
Cheers
skyrim.ini
Code:
[General]
sLanguage=ENGLISH
fFlickeringLightDistance=8192
iFPSClamp=60
uExterior Cell Buffer=36
[Display]
fShadowLODMaxStartFade=1000.0
fSpecularLODMaxStartFade=2000.0
fLightLODMaxStartFade=3500.0
iShadowMapResolutionPrimary=2048
bAllowScreenshot=1
iPresentInterval=0
fDefaultWorldFOV=90
fDefault1stPersonFOV=90.0000
fSunShadowUpdateTime=0
fSunUpdateThreshold=2.0
[Audio]
fMusicDuckingSeconds=6.0
fMusicUnDuckingSeconds=8.0
fMenuModeFadeOutTime=3.0
fMenuModeFadeInTime=1.0
[Grass]
bAllowCreateGrass=1
bAllowLoadGrass=0
iMaxGrassTypesPerTexure=7
iMinGrassSize=75
[GeneralWarnings]
SGeneralMasterMismatchWarning=One or more plugins could not find the correct versions of the master files they depend on. Errors may occur during load or game play. Check the "Warnings.txt" file for more information.
[Archive]
sResourceArchiveList=Skyrim - Misc.bsa, Skyrim - Shaders.bsa, Skyrim - Textures.bsa, Skyrim - Interface.bsa, Skyrim - Animations.bsa, Skyrim - Meshes.bsa, Skyrim - Sounds.bsa
sResourceArchiveList2=Skyrim - Voices.bsa, Skyrim - VoicesExtra.bsa
bInvalidateOlderFiles=0
SInvalidationFile=ArchiveInvalidation.txt
[Combat]
fMagnetismStrafeHeadingMult=0.0
fMagnetismLookingMult=0.0
[Papyrus]
fUpdateBudgetMS=1.6
fExtraTaskletBudgetMS=1.6
fPostLoadUpdateTimeMS=2000.0
iMinMemoryPageSize=256
iMaxMemoryPageSize=1024
iMaxAllocatedMemoryBytes=115200
bEnableLogging=0
bEnableTrace=0
bLoadDebugInformation=0
bEnableProfiling=0
[Water]
bReflectLODObjects=1
bReflectLODLand=1
bReflectSky=1
bReflectLODTrees=1
skyrimprefs.ini
Code:
[General]
fdefaultfov=90
fBrightLightColorB=1.0000
fBrightLightColorG=1.0000
fBrightLightColorR=1.0000
iStoryManagerLoggingEvent=-1
bEnableStoryManagerLogging=0
[Imagespace]
bDoDepthOfField=1
iRadialBlurLevel=2
[Display]
iBlurDeferredShadowMask=3
fInteriorShadowDistance=3000.0000
fShadowDistance=4000.0000
iShadowMapResolutionSecondary=1024
iShadowMapResolutionPrimary=1024
iShadowSplitCount=2
iMaxAnisotropy=1
fLeafAnimDampenDistEnd=4600.0000
fLeafAnimDampenDistStart=3600.0000
fTreesMidLODSwitchDist=10000000.0000
fGamma=1.2400
fDecalLOD2=1500.0000
fDecalLOD1=1000.0000
fSpecularLODStartFade=2000.0000
fShadowLODStartFade=200.0000
fLightLODStartFade=3500.0000
iTexMipMapMinimum=0
iTexMipMapSkip=0
iWaterMultiSamples=0
iMultiSample=0
iShadowMode=3
bTreesReceiveShadows=1
bDrawLandShadows=1
bFull Screen=1
iSize H=1440
iSize W=2560
fMeshLODFadePercentDefault=1.2000
fMeshLODFadeBoundDefault=256.0000
fMeshLODLevel2FadeTreeDistance=2048.0000
fMeshLODLevel1FadeTreeDistance=2844.0000
fMeshLODLevel2FadeDist=10000000.0000
fMeshLODLevel1FadeDist=10000000.0000
iScreenShotIndex=2
bShadowMaskZPrepass=0
bMainZPrepass=0
iMaxSkinDecalsPerFrame=250
iMaxDecalsPerFrame=800
bFloatPointRenderTarget=1
sD3DDevice="NVIDIA GeForce GTX 980 Ti"
bFXAAEnabled=0
iShadowMapResolution=1024
fShadowBiasScale=0.1500
iShadowMaskQuarter=4
iAdapter=0
ipresentinterval=0
iShadowFilter=3
bShadowsOnGrass=1
bTransparencyMultisampling=0
bDeferredShadows=1
bDrawShadows=1
[Grass]
b30GrassVS=0
bAllowLoadGrass=0
bAllowCreateGrass=1
fGrassStartFadeDistance=7000.0000
fGrassMaxStartFadeDistance=7000.0000
fGrassMinStartFadeDistance=0.0000
[MAIN]
bGamepadEnable=1
bCrosshairEnabled=1
fHUDOpacity=1.0000
bSaveOnPause=1
bSaveOnTravel=1
bSaveOnWait=1
bSaveOnRest=1
fSkyCellRefFadeDistance=150000.0000
[GamePlay]
bShowFloatingQuestMarkers=1
bShowQuestMarkers=1
iDifficulty=0
[Interface]
bDialogueSubtitles=0
bGeneralSubtitles=0
fMouseCursorSpeed=1.0000
bShowCompass=1
[Controls]
fForegroundMouseAccelBase=0
fForegroundMouseAccelTop=0
fForegroundMouseBase=0
fForegroundMouseMult=0
fGamepadHeadingSensitivity=1.0000
fMouseHeadingSensitivity=0.0125
bAlwaysRunByDefault=1
bInvertYValues=0
bGamePadRumble=1
bUseKinect=0
[Particles]
iMaxDesired=750
[SaveGame]
fAutosaveEveryXMins=15.0000
[AudioMenu]
fAudioMasterVolume=1.0000
fVal7=1.0000
uID7=352526517
fVal6=1.0000
uID6=352526514
fVal5=1.0000
uID5=352527896
fVal4=1.0000
uID4=352526518
fVal3=1.0000
uID3=94881
fVal2=0.4000
uID2=466532
fVal1=1.0000
uID1=554685
fVal0=0.8000
uID0=1007612
[Clouds]
fCloudLevel2Distance=262144.0000
fCloudLevel1Distance=32768.0000
fCloudLevel0Distance=16384.0000
fCloudNearFadeDistance=9000.0000
[TerrainManager]
fTreeLoadDistance=75000.0000
fBlockMaximumDistance=250000.0000
fBlockLevel1Distance=70000.0000
fBlockLevel0Distance=35000.0000
fSplitDistanceMult=1.5000
bShowLODInEditor=0
[NavMesh]
fObstacleAlpha=0.5000
fCoverSideHighAlpha=0.8000
fCoverSideLowAlpha=0.6500
fEdgeFullAlpha=1.0000
fEdgeHighAlpha=0.7500
fEdgeLowAlpha=0.5000
fTriangleFullAlpha=0.7000
fTriangleHighAlpha=0.3500
fTriangleLowAlpha=0.2000
fLedgeBoxHalfHeight=25.0000
fEdgeDistFromVert=10.0000
fEdgeThickness=10.0000
fPointSize=2.5000
[Trees]
bRenderSkinnedTrees=1
uiMaxSkinnedTreesToRender=20
[Decals]
uMaxDecals=1000
bDecals=1
bSkinnedDecals=1
uMaxSkinDecals=100
uMaxSkinDecalsPerActor=60
[LOD]
fLODFadeOutMultObjects=15.0000
fLODFadeOutMultItems=15.0000
fLODFadeOutMultActors=15.0000
fLODFadeOutMultSkyCell=1.0000
[Launcher]
bEnableFileSelection=1
bShowAllResolutions=1
uLastAspectRatio=3
[BlurShaderHDR]
bDoHighDynamicRange=1
[BlurShader]
bUseBlurShader=0
[Water]
iWaterReflectHeight=512
iWaterReflectWidth=512
bUseWaterDisplacements=1
bUseWaterRefractions=1
bUseWaterReflections=1
bUseWaterDepth=1
enblocal.ini
Code:
[PROXY]
EnableProxyLibrary=true
InitProxyFunctions=true
ProxyLibrary=d3d9_smaa.dll
[GLOBAL]
UsePatchSpeedhackWithoutGraphics=false
UseDefferedRendering=true
IgnoreCreationKit=true
[PERFORMANCE]
SpeedHack=true
EnableOcclusionCulling=true
[MULTIHEAD]
ForceVideoAdapterIndex=false
VideoAdapterIndex=0
[MEMORY]
ExpandSystemMemoryX64=true
ReduceSystemMemoryUsage=true
DisableDriverMemoryManager=false
DisablePreloadToVRAM=false
EnableUnsafeMemoryHacks=false
ReservedMemorySizeMb=512
VideoMemorySizeMb=12288
EnableCompression=false
AutodetectVideoMemorySize=false
[WINDOW]
ForceBorderless=false
ForceBorderlessFullscreen=false
[ENGINE]
ForceAnisotropicFiltering=true
MaxAnisotropy=16
ForceLodBias=false
LodBias=0.0
AddDisplaySuperSamplingResolutions=false
EnableVSync=false
VSyncSkipNumFrames=0
[LIMITER]
WaitBusyRenderer=false
EnableFPSLimit=false
FPSLimit=60.0
[INPUT]
//shift
KeyCombination=16
//f12
KeyUseEffect=123
//home
KeyFPSLimit=36
//num /       106
KeyShowFPS=106
//print screen
KeyScreenshot=44
//enter
KeyEditor=13
//f4
KeyFreeVRAM=115
[ADAPTIVEQUALITY]
Enable=false
Quality=1
DesiredFPS=30.0
[ANTIALIASING]
EnableEdgeAA=true
EnableTemporalAA=false
EnableSubPixelAA=true
EnableTransparencyAA=false
[FIX]
FixGameBugs=true
FixParallaxBugs=true
FixParallaxTerrain=false
FixAliasedTextures=true
IgnoreInventory=true
FixTintGamma=false
RemoveBlur=false
FixSubSurfaceScattering=true
FixSkyReflection=true
FixCursorVisibility=true
FixLag=false
[LONGEXPOSURE]
EnableLongExposureMode=false
Time=1.0
BlendMax=0.0
enbseries.ini
Code:
//      -- RealVision ENB B FULL v279b --
//                optimized for
//   Climates of Tamriel & Enhanced Lights & FX
//         ENB settings by SkyrimTuner
[GLOBAL]
UseEffect=true
[EFFECT]
UseOriginalPostProcessing=false
UseOriginalObjectsProcessing=false
EnableBloom=true
EnableLens=true
EnableAdaptation=true
EnableDepthOfField=true
EnableAmbientOcclusion=false
EnableDetailedShadow=true
EnableSunRays=true
EnableSunGlare=true
EnableSkyLighting=true
EnableImageBasedLighting=true
EnableReflection=false
EnableSoftParticles=true
EnableParticleLights=true
EnableSubSurfaceScattering=true
EnableWater=true
EnableUnderwater=true
EnableCloudShadows=true
EnableVolumetricRays=true
EnableProceduralSun=false
EnableMist=true
[COLORCORRECTION]
UsePaletteTexture=true
Brightness=1.0
GammaCurve=1.0
UseProceduralCorrection=false
[WEATHER]
EnableMultipleWeathers=false
[TIMEOFDAY]
Enable=false
DawnDuration=1.5
SunriseTime=7.25
DayTime=13.5
SunsetTime=19.25
DuskDuration=1.5
NightTime=1.0
[NIGHTDAY]
DetectorOldVersion=false
DetectorDefaultDay=false
DetectorLevelDay=0.7
DetectorLevelNight=0.12
DetectorLevelCurve=0.5
[ADAPTATION]
ForceMinMaxValues=false
AdaptationSensitivity=0.1
AdaptationTime=0.2
AdaptationMin=0.2
AdaptationMax=1.0
[BLOOM]
AmountSunrise=0.3
AmountDay=0.32
AmountSunset=0.3
AmountNight=0.1
AmountInteriorDay=0.3
AmountInteriorNight=0.2
BlueShiftAmountSunrise=1.5
BlueShiftAmountDay=2.0
BlueShiftAmountSunset=1.5
BlueShiftAmountNight=0.2
BlueShiftAmountInteriorDay=1.0
BlueShiftAmountInteriorNight=1.0
IgnoreWeatherSystem=false
[LENS]
ReflectionIntensitySunrise=0.45
ReflectionIntensityDay=0.5
ReflectionIntensitySunset=0.4
ReflectionIntensityNight=0.13
ReflectionIntensityInteriorDay=0.12
ReflectionIntensityInteriorNight=0.12
ReflectionPowerSunrise=0.9
ReflectionPowerDay=1.1
ReflectionPowerSunset=0.9
ReflectionPowerNight=2.4
ReflectionPowerInteriorDay=2.0
ReflectionPowerInteriorNight=2.0
DirtIntensitySunrise=1.0
DirtIntensityDay=1.0
DirtIntensitySunset=1.0
DirtIntensityNight=1.0
DirtIntensityInteriorDay=1.0
DirtIntensityInteriorNight=1.0
DirtPowerSunrise=2.0
DirtPowerDay=2.0
DirtPowerSunset=2.0
DirtPowerNight=2.0
DirtPowerInteriorDay=2.0
DirtPowerInteriorNight=2.0
[SSAO_SSIL]
EnableSupersampling=false
UseIndirectLighting=true
UseComplexIndirectLighting=true
UseComplexAmbientOcclusion=true
UseAmbientIndirectLighting=true
SamplingQuality=0
SamplingPrecision=0
SamplingRange=0.6
FadeFogRange=1.0
SizeScale=0.5
SourceTexturesScale=0.7
EnableComplexFilter=true
FilterQuality=0
FilterType=0
AOAmount=0.75
AOAmountInterior=1.0
ILAmount=3.5
ILAmountInterior=1.0
AOIntensity=1.0
AOIntensityInterior=1.0
AOType=0
ILType=0
AOMixingType=0
AOMixingTypeInterior=0
EnableDenoiser=true
[SKYLIGHTING]
Quality=0
FilterQuality=0
AmbientMinLevelSunrise=0.7
AmbientMinLevelDay=0.9
AmbientMinLevelSunset=0.7
AmbientMinLevelNight=0.5
AmbientMinLevelInteriorDay=0.1
AmbientMinLevelInteriorNight=0.1
[ENVIRONMENT]
DirectLightingIntensitySunrise=1.0
DirectLightingIntensityDay=1.25
DirectLightingIntensitySunset=1.0
DirectLightingIntensityNight=1.0
DirectLightingIntensityInteriorDay=1.0
DirectLightingIntensityInteriorNight=1.0
DirectLightingCurveSunrise=1.6
DirectLightingCurveDay=1.7
DirectLightingCurveSunset=1.6
DirectLightingCurveNight=1.0
DirectLightingCurveInteriorDay=1.0
DirectLightingCurveInteriorNight=1.0
DirectLightingDesaturationSunrise=0.8
DirectLightingDesaturationDay=0.8
DirectLightingDesaturationSunset=0.8
DirectLightingDesaturationNight=0.2
DirectLightingDesaturationInteriorDay=0.0
DirectLightingDesaturationInteriorNight=0.0
SpecularAmountMultiplierSunrise=1.0
SpecularAmountMultiplierDay=1.0
SpecularAmountMultiplierSunset=1.0
SpecularAmountMultiplierNight=2.1
SpecularAmountMultiplierInteriorDay=1.0
SpecularAmountMultiplierInteriorNight=1.0
SpecularPowerMultiplierSunrise=1.0
SpecularPowerMultiplierDay=1.0
SpecularPowerMultiplierSunset=1.0
SpecularPowerMultiplierNight=2.0
SpecularPowerMultiplierInteriorDay=1.0
SpecularPowerMultiplierInteriorNight=1.0
SpecularFromLightSunrise=0.1
SpecularFromLightDay=0.1
SpecularFromLightSunset=0.1
SpecularFromLightNight=0.1
SpecularFromLightInteriorDay=0.8
SpecularFromLightInteriorNight=0.8
AmbientLightingIntensitySunrise=1.2
AmbientLightingIntensityDay=1.33
AmbientLightingIntensitySunset=1.2
AmbientLightingIntensityNight=0.5
AmbientLightingIntensityInteriorDay=0.75
AmbientLightingIntensityInteriorNight=0.75
AmbientLightingCurveSunrise=0.9
AmbientLightingCurveDay=0.55
AmbientLightingCurveSunset=0.9
AmbientLightingCurveNight=1.0
AmbientLightingCurveInteriorDay=0.55
AmbientLightingCurveInteriorNight=0.55
AmbientLightingDesaturationSunrise=0.8
AmbientLightingDesaturationDay=0.8
AmbientLightingDesaturationSunset=0.8
AmbientLightingDesaturationNight=0.0
AmbientLightingDesaturationInteriorDay=0.0
AmbientLightingDesaturationInteriorNight=0.0
AmbientColorFilterAmountSunrise=0.0
AmbientColorFilterAmountDay=0.0
AmbientColorFilterAmountSunset=0.0
AmbientColorFilterAmountNight=0.0
AmbientColorFilterAmountInteriorDay=0.0
AmbientColorFilterAmountInteriorNight=0.0
AmbientColorFilterTopSunrise=1, 1, 1
AmbientColorFilterTopDay=1, 1, 1
AmbientColorFilterTopSunset=1, 1, 1
AmbientColorFilterTopNight=1, 1, 1
AmbientColorFilterTopInteriorDay=1, 1, 1
AmbientColorFilterTopInteriorNight=1, 1, 1
AmbientColorFilterMiddleSunrise=0, 0, 0
AmbientColorFilterMiddleDay=0, 0, 0
AmbientColorFilterMiddleSunset=0, 0, 0
AmbientColorFilterMiddleNight=0, 0, 0
AmbientColorFilterMiddleInteriorDay=0, 0, 0
AmbientColorFilterMiddleInteriorNight=0, 0, 0
AmbientColorFilterBottomSunrise=1, 1, 1
AmbientColorFilterBottomDay=1, 1, 1
AmbientColorFilterBottomSunset=1, 1, 1
AmbientColorFilterBottomNight=1, 1, 1
AmbientColorFilterBottomInteriorDay=1, 1, 1
AmbientColorFilterBottomInteriorNight=1, 1, 1
PointLightingIntensitySunrise=1.0
PointLightingIntensityDay=1.0
PointLightingIntensitySunset=1.0
PointLightingIntensityNight=1.15
PointLightingIntensityInteriorDay=1.0
PointLightingIntensityInteriorNight=1.0
PointLightingCurveSunrise=0.9
PointLightingCurveDay=0.9
PointLightingCurveSunset=0.9
PointLightingCurveNight=0.6
PointLightingCurveInteriorDay=1.0
PointLightingCurveInteriorNight=1.0
PointLightingDesaturationSunrise=0.5
PointLightingDesaturationDay=0.5
PointLightingDesaturationSunset=0.5
PointLightingDesaturationNight=0.2
PointLightingDesaturationInteriorDay=0.2
PointLightingDesaturationInteriorNight=0.2
ParticleLightsIntensitySunrise=1.0
ParticleLightsIntensityDay=1.0
ParticleLightsIntensitySunset=1.0
ParticleLightsIntensityNight=1.0
ParticleLightsIntensityInteriorDay=0.15
ParticleLightsIntensityInteriorNight=0.15
FogColorMultiplierSunrise=0.65
FogColorMultiplierDay=0.6
FogColorMultiplierSunset=0.65
FogColorMultiplierNight=0.2
FogColorMultiplierInteriorDay=1.0
FogColorMultiplierInteriorNight=1.0
FogColorCurveSunrise=0.75
FogColorCurveDay=1.0
FogColorCurveSunset=0.75
FogColorCurveNight=1.0
FogColorCurveInteriorDay=1.0
FogColorCurveInteriorNight=1.0
ColorPowSunrise=1.3
ColorPowDay=1.3
ColorPowSunset=1.3
ColorPowNight=1.0
ColorPowInteriorDay=1.0
ColorPowInteriorNight=1.0
[SKY]
Enable=true
DisableWrongSkyMath=true
StarsIntensity=1.5
StarsCurve=1.0
AuroraBorealisIntensity=1.0
AuroraBorealisCurve=0.7
CloudsIntensitySunrise=1.5
CloudsIntensityDay=1.6
CloudsIntensitySunset=1.5
CloudsIntensityNight=0.4
CloudsIntensityInteriorDay=1.0
CloudsIntensityInteriorNight=1.0
CloudsCurveSunrise=1.0
CloudsCurveDay=1.5
CloudsCurveSunset=1.0
CloudsCurveNight=1.0
CloudsCurveInteriorDay=1.0
CloudsCurveInteriorNight=1.0
CloudsDesaturationSunrise=0.0
CloudsDesaturationDay=0.0
CloudsDesaturationSunset=0.0
CloudsDesaturationNight=0.3
CloudsDesaturationInteriorDay=0.0
CloudsDesaturationInteriorNight=0.0
CloudsOpacitySunrise=0.75
CloudsOpacityDay=0.75
CloudsOpacitySunset=0.75
CloudsOpacityNight=0.25
CloudsOpacityInteriorDay=0.75
CloudsOpacityInteriorNight=0.25
CloudsEdgeClamp=0.5
CloudsEdgeIntensity=2.0
CloudsEdgeFadeRange=1.0
CloudsEdgeMoonMultiplier=4.0
GradientIntensitySunrise=1.0
GradientIntensityDay=0.72
GradientIntensitySunset=1.0
GradientIntensityNight=0.2
GradientIntensityInteriorDay=2.0
GradientIntensityInteriorNight=1.0
GradientDesaturationSunrise=0.0
GradientDesaturationDay=0.0
GradientDesaturationSunset=0.0
GradientDesaturationNight=0.0
GradientDesaturationInteriorDay=0.0
GradientDesaturationInteriorNight=0.0
GradientTopIntensitySunrise=1.5
GradientTopIntensityDay=0.72
GradientTopIntensitySunset=1.5
GradientTopIntensityNight=0.9
GradientTopIntensityInteriorDay=1.0
GradientTopIntensityInteriorNight=1.0
GradientTopCurveSunrise=0.7
GradientTopCurveDay=0.7
GradientTopCurveSunset=0.7
GradientTopCurveNight=0.8
GradientTopCurveInteriorDay=1.0
GradientTopCurveInteriorNight=1.0
GradientMiddleIntensitySunrise=2.3
GradientMiddleIntensityDay=2.3
GradientMiddleIntensitySunset=2.3
GradientMiddleIntensityNight=0.7
GradientMiddleIntensityInteriorDay=1.0
GradientMiddleIntensityInteriorNight=1.0
GradientMiddleCurveSunrise=1.0
GradientMiddleCurveDay=1.0
GradientMiddleCurveSunset=1.0
GradientMiddleCurveNight=0.8
GradientMiddleCurveInteriorDay=1.0
GradientMiddleCurveInteriorNight=1.0
GradientHorizonIntensitySunrise=2.5
GradientHorizonIntensityDay=2.5
GradientHorizonIntensitySunset=2.5
GradientHorizonIntensityNight=0.8
GradientHorizonIntensityInteriorDay=1.0
GradientHorizonIntensityInteriorNight=1.0
GradientHorizonCurveSunrise=1.0
GradientHorizonCurveDay=1.0
GradientHorizonCurveSunset=1.0
GradientHorizonCurveNight=0.8
GradientHorizonCurveInteriorDay=1.0
GradientHorizonCurveInteriorNight=1.0
SunIntensitySunrise=1.0
SunIntensityDay=0.8
SunIntensitySunset=1.0
SunIntensityNight=1.0
SunIntensityInteriorDay=1.0
SunIntensityInteriorNight=1.0
SunDesaturationSunrise=0.1
SunDesaturationDay=0.4
SunDesaturationSunset=0.1
SunDesaturationNight=0.0
SunDesaturationInteriorDay=0.4
SunDesaturationInteriorNight=0.1
SunColorFilterSunrise=1, 1, 1
SunColorFilterDay=1, 1, 1
SunColorFilterSunset=1, 1, 1
SunColorFilterNight=1, 1, 1
SunColorFilterInteriorDay=1, 1, 1
SunColorFilterInteriorNight=1, 1, 1
SunGlowIntensitySunrise=0.1
SunGlowIntensityDay=0.2
SunGlowIntensitySunset=0.1
SunGlowIntensityNight=0.0
SunGlowIntensityInteriorDay=0.0
SunGlowIntensityInteriorNight=0.0
SunGlowHazinessSunrise=0.0
SunGlowHazinessDay=0.0
SunGlowHazinessSunset=0.0
SunGlowHazinessNight=0.0
SunGlowHazinessInteriorDay=0.0
SunGlowHazinessInteriorNight=0.0
SunCoronaIntensity=1.0
SunCoronaCurve=0.8
SunCoronaDesaturation=0.7
MoonIntensitySunrise=1.0
MoonIntensityDay=1.0
MoonIntensitySunset=1.0
MoonIntensityNight=1.2
MoonIntensityInteriorDay=1.0
MoonIntensityInteriorNight=1.0
MoonCurveSunrise=1.0
MoonCurveDay=1.0
MoonCurveSunset=1.0
MoonCurveNight=1.0
MoonCurveInteriorDay=1.0
MoonCurveInteriorNight=1.0
MoonDesaturationSunrise=0.0
MoonDesaturationDay=0.0
MoonDesaturationSunset=0.0
MoonDesaturationNight=0.0
MoonDesaturationInteriorDay=0.0
MoonDesaturationInteriorNight=0.0
[OBJECT]
SubSurfaceScatteringMultiplierSunrise=0.0
SubSurfaceScatteringMultiplierDay=0.0
SubSurfaceScatteringMultiplierSunset=0.0
SubSurfaceScatteringMultiplierNight=0.0
SubSurfaceScatteringMultiplierInteriorDay=0.0
SubSurfaceScatteringMultiplierInteriorNight=0.0
SubSurfaceScatteringPowerSunrise=8.0
SubSurfaceScatteringPowerDay=8.0
SubSurfaceScatteringPowerSunset=8.0
SubSurfaceScatteringPowerNight=8.0
SubSurfaceScatteringPowerInteriorDay=8.0
SubSurfaceScatteringPowerInteriorNight=8.0
SpecularAmountMultiplierNight=1.0
SpecularPowerMultiplierNight=1.0
[VEGETATION]
SubSurfaceScatteringMultiplierSunrise=1.0
SubSurfaceScatteringMultiplierDay=1.0
SubSurfaceScatteringMultiplierSunset=1.0
SubSurfaceScatteringMultiplierNight=1.0
SubSurfaceScatteringMultiplierInteriorDay=1.0
SubSurfaceScatteringMultiplierInteriorNight=1.0
SubSurfaceScatteringPowerSunrise=1.0
SubSurfaceScatteringPowerDay=1.0
SubSurfaceScatteringPowerSunset=1.0
SubSurfaceScatteringPowerNight=1.0
SubSurfaceScatteringPowerInteriorDay=1.0
SubSurfaceScatteringPowerInteriorNight=1.0
[EYES]
SubSurfaceScatteringMultiplierSunrise=0.36
SubSurfaceScatteringMultiplierDay=0.48
SubSurfaceScatteringMultiplierSunset=0.36
SubSurfaceScatteringMultiplierNight=0.24
SubSurfaceScatteringMultiplierInteriorDay=0.24
SubSurfaceScatteringMultiplierInteriorNight=0.24
SubSurfaceScatteringPowerSunrise=4.9
SubSurfaceScatteringPowerDay=0.5
SubSurfaceScatteringPowerSunset=4.9
[LIGHTSPRITE]
IntensitySunrise=1.1
IntensityDay=1.1
IntensitySunset=1.1
IntensityNight=0.9
CurveSunrise=1.2
CurveDay=1.2
CurveSunset=1.2
CurveNight=1.0
[WINDOWLIGHT]
IntensityDay=1.0
IntensitySunset=1.0
IntensityNight=1.0
CurveSunrise=1.0
CurveDay=1.0
CurveSunset=1.0
CurveNight=1.0
[VOLUMETRICFOG]
EnableShadows=true
IntensityDay=1.2
IntensitySunset=1.2
IntensityNight=0.2
CurveSunrise=0.5
CurveDay=0.5
CurveSunset=0.5
CurveNight=0.8
LightingInfluenceSunrise=1.0
LightingInfluenceDay=1.0
LightingInfluenceSunset=1.0
LightingInfluenceNight=1.0
LightingInfluenceInteriorDay=1.0
LightingInfluenceInteriorNight=1.0
OpacitySunrise=0.67
OpacityDay=0.67
OpacitySunset=0.67
OpacityNight=0.67
OpacityInteriorDay=0.67
OpacityInteriorNight=0.67
[FIRE]
IntensityDay=1.0
IntensitySunset=1.0
IntensityNight=2.0
CurveSunrise=0.7
CurveDay=0.7
CurveSunset=0.7
CurveNight=0.7
AdditiveBlending=true
[PARTICLE]
IntensityDay=1.0
IntensitySunset=1.0
IntensityNight=0.6
LightingInfluenceInteriorNight=0.5
[DEPTHOFFIELD]
Quality=0
FadeTime=0.2
[SHADOW]
ShadowCastersFix=false
UseBilateralShadowFilter=true
ShadowQualityFix=true
DetailedShadowQuality=0
ShadowFilterQuality=0
ShadowBlurRange=4.0
ShadowBlurRangeInterior=2.0
[RAYS]
SunRaysMultiplierSunrise=1.1
SunRaysMultiplierDay=1.0
SunRaysMultiplierSunset=1.1
SunRaysMultiplierNight=0.4
SunRaysMultiplierInteriorDay=0.4
SunRaysMultiplierInteriorNight=0.4
[REFLECTION]
Quality=0
FilterQuality=0
FilterBluriness=0.3
SizeScale=0.35
SourceTexturesScale=0.25
Amount=1.0
AmountInterior=1.0
Power=1.0
PowerInterior=1.0
GlosinessMin=0.0
GlosinessMax=0.0
EnableDenoiser=true
DenoiserType=0
ExteriorEnable=true
InteriorEnable=true
[IMAGEBASEDLIGHTING]
AdditiveAmountSunrise=0.08
AdditiveAmountDay=0.08
AdditiveAmountSunset=0.08
AdditiveAmountNight=0.08
AdditiveAmountInteriorDay=0.08
AdditiveAmountInteriorNight=0.08
MultiplicativeAmountSunrise=0.0
MultiplicativeAmountDay=0.0
MultiplicativeAmountSunset=0.0
MultiplicativeAmountNight=0.0
MultiplicativeAmountInteriorDay=0.0
MultiplicativeAmountInteriorNight=0.0
ReflectiveAmountSunrise=0.2
ReflectiveAmountDay=0.2
ReflectiveAmountSunset=0.2
ReflectiveAmountNight=0.2
ReflectiveAmountInteriorDay=0.2
ReflectiveAmountInteriorNight=0.2
[RAIN]
Enable=true
EnableAntialiasing=false
EnableSupersampling=true
MotionStretch=0.9
MotionTransparency=0.85
[SUBSURFACESCATTERING]
EnableTextureAlpha=true
Quality=0
Radius=4.0
Amount=0.66
EpidermalAmount=0.44
SubdermalAmount=0.002
EpidermalDiffuseSaturation=0.06
SubdermalDiffuseSaturation=0.09
EpidermalMix=0.5
SubdermalMix=0.22
SubdermalTranslucency=0.27
SubdermalPhase=0.009
[WATER]
EnablePreCache=false
EnableDispersion=true
EnableCaustics=true
EnableParallax=true
EnableShadow=true
EnableVolumetricShadow=true
EnableLighting=true
EnableSelfReflection=true
EnableDisplacement=true
DisplacementQuality=0
DisplacementFilterQuality=0
ShadowQuality=0
EnableShadowNoise=false
ReflectionAmount=1.0
FrennelMultiplier=1.0
FrennelMin=0.0
FrennelMax=1.0
DispersionAmount=0.3
CausticsAmount=3.0
SunSpecularMultiplier=1.52
SunScatteringMultiplier=4.5
SunLightingMultiplier=0.88
WetMultiplier=0.72
WavesAmplitudeSunrise=0.8
WavesAmplitudeDay=0.5
WavesAmplitudeSunset=0.8
WavesAmplitudeNight=0.8
WavesAmplitudeInteriorDay=1.0
WavesAmplitudeInteriorNight=1.0
Muddiness=0.5
[UNDERWATER]
EnableParallax=true
EnableDisplacement=false
EnableSilhouette=true
EnableBlurring=true
EnableReflection=true
EnableShadow=true
ShadowQuality=0
DispersionAmount=0.9
TransparencyFade=1.0
TransparencyCurve=1.5
DeepnessFade=1.0
DeepnessDarkening=0.5
TintAmount=2.0
TintFade=2.0
SunScatteringMultiplier=1.0
[CLOUDSHADOWS]
EnableAtNight=false
OpacitySunrise=0.45
OpacityDay=0.45
OpacitySunset=0.45
OpacityNight=0.2
OpacityInteriorDay=0.45
[VOLUMETRICRAYS]
Quality=0
IntensitySunrise=0.12
IntensityDay=0.15
IntensitySunset=0.12
IntensityNight=0.05
IntensityInteriorNight=0.05
DensitySunrise=1.0
DensityDay=1.0
DensitySunset=1.0
DensityNight=1.0
DensityInteriorDay=1.0
DensityInteriorNight=1.0
SkyColorAmountSunrise=0.5
SkyColorAmountDay=0.5
SkyColorAmountSunset=0.5
SkyColorAmountNight=0.5
SkyColorAmountInteriorDay=0.5
SkyColorAmountInteriorNight=0.5
[PROCEDURALSUN]
Size=1.0
EdgeSoftness=0.5
GlowIntensitySunrise=0.4
GlowIntensityDay=0.4
GlowIntensitySunset=0.4
GlowIntensityNight=0.4
GlowIntensityInteriorDay=0.4
GlowIntensityInteriorNight=0.4
GlowCurveSunrise=1.0
GlowCurveDay=1.0
GlowCurveSunset=1.0
GlowCurveNight=1.0
GlowCurveInteriorDay=1.0
GlowCurveInteriorNight=1.0
[MIST]
EnableAnchors=false
AnchorsAmountSunrise=1.0
AnchorsAmountDay=1.0
AnchorsAmountSunset=1.0
AnchorsAmountNight=1.0
AnchorsAmountInteriorDay=1.0
AnchorsAmountInteriorNight=1.0
ColorFromEnvironmentFog=0.4
SkyLightingAmountSunrise=0.4
SkyLightingAmountDay=0.62
SkyLightingAmountSunset=0.36
SkyLightingAmountNight=1.26
SkyLightingAmountInteriorDay=1.0
SkyLightingAmountInteriorNight=1.0
SunLightingAmountSunrise=0.65
SunLightingAmountDay=0.65
SunLightingAmountSunset=0.65
SunLightingAmountNight=0.65
SunLightingAmountInteriorDay=0.65
SunLightingAmountInteriorNight=0.65
DesaturationDay=0.0
RelativeToCameraSunrise=0.0
RelativeToCameraDay=0.0
RelativeToCameraSunset=0.0
RelativeToCameraNight=0.0
RelativeToCameraInteriorDay=0.0
RelativeToCameraInteriorNight=0.0
VerticalOffsetSunrise=-15.0
VerticalOffsetDay=-35.0
VerticalOffsetSunset=-15.0
VerticalOffsetNight=-10.0
VerticalOffsetInteriorDay=-35.0
VerticalOffsetInteriorNight=-35.0
DensitySunrise=1.5
DensityDay=1.5
DensitySunset=1.5
DensityNight=1.5
DensityInteriorDay=1.5
DensityInteriorNight=1.5
VerticalFadeSunrise=4.0
VerticalFadeDay=4.0
VerticalFadeSunset=4.0
VerticalFadeNight=4.0
VerticalFadeInteriorDay=4.0
VerticalFadeInteriorNight=4.0
DistanceFadeSunrise=0.0
DistanceFadeDay=0.0
DistanceFadeSunset=0.0
DistanceFadeNight=0.0
DistanceFadeInteriorDay=0.0
DistanceFadeInteriorNight=0.0
BottomTopSunrise=0.0
BottomTopDay=0.0
BottomTopSunset=0.0
BottomTopNight=0.0
BottomTopInteriorDay=0.0
BottomTopInteriorNight=0.0
ExponentialFadeSunrise=1.0
ExponentialFadeDay=1.0
ExponentialFadeSunset=1.0
ExponentialFadeNight=1.0
ExponentialFadeInteriorDay=1.0
ExponentialFadeInteriorNight=1.0
I don't think this game looks right at all. I've installed most of the mods that are in the OP, and I have an ENB running... but it just looks a bit flat and gash. I'm thinking it might be a problem with Win10?
Its in enbseries.ini
[Effect]
Or press Shift+Enter ingame, then tick the box marked "Enable Depth of Field" and Save. If that fails make sure you have a file called enbeffectprepass.fx in your Skyrim folder.
Looks like some kind of Lighting mod as well? Something is removing distance fog at anyrate. Non-vanilla lighting and "look" is entirely down to mods and ENB/SweetFX. If you don't like the look of one ENB try another. I use ENB for shadows and Sun/God Rays only and let Sweet FX and RLO handle everything else.
