- 12 Sep 2012
- Surrey
Tabbing out to see it wont work, so try and run it as an overlay or on a second screen. Or you can buy the Core Temp app if that is still around.
look for speed drops and core voltage is if you see it backing off means you're being throttled; and most likely because vrms getting too hot; its fairly easy to ghetto mod to cool them though
Those screen shots don't tell anything except that the cpu was idling due to the alt-tab just like avenged said. This bench which would load the fx8 up well enough and sill run in windowed mode would be this.
http://www.guru3d.com/files-details/monster-hunter-official-benchmark-download.html
What you need to do is use hwmonitor to show the volts and temps,
and use afterburner to log the cpu usage and gpu utilization when gaming.
In atilla i believe the fx series perform very poorly but it should be better than what you are getting.
I can guarantee like someone else has said your board will throttle the cpu in games that use high cpu load and lots of threads.
Even if your reduce the voltage of the cpu the board will throttle as it doesn't have apm, neither does it have any vrm cooling and it only has a 4 pin atx connector.
Get yourself a 78lmtusb3 for £38-43 and it'll solve a lot of time and is the cheapest solution bar 2nd hand high spec am3+ boards.
Here's where you'll be looking at when running the bench that i linked above in 1080p windowed mode. You would see the clocks throttling circled in red.
Also keep an ote of the core temp and cpu temp.
yes 100% either due to bios or the boards inability to support your cpu properly you are stuck at 1400mhz it's not clocking up. That is why you are seeing such crap performance.
But try the bencmark i showed you to test it's not just staying at 1400mhz in Atila.
edit can you do a screen print of cpu0z to show us the bios thats installed on the mboard please.
Ok I'd try loading default settings or resetting your cmos.
Something in your bios is causing your cpu to stay at 7x which is 1400mhz.
if that doesn't change anything then have a look at setting your windows power mode to balanced or high performance.
If still stuck at 1400mhz then we need some screenshots of your bios so we can what settings are enabled, If we can go through some settings then we can maybe save yourself a mbaord. But like i said for £38-£43 you could get a board and it will run properly from out of the box and will even support an overclock to 4.5ghz with ease, providing you have a good cpu cooler.
I've already tried all that! A new motherboard it is!
If & when i get a new mobo, I'm gona take it so someone can install it properly. PC world? As I don't trust the local shops.
I've got my eye on 3, which one do you think?
Asus Sabertooth 990FX R2.0
Asus Crosshair Formula V Formula Z
Gigabyte 990FXA UD3
How far do you want to clock ? and what cpu cooler do you have?
Do you need sli/cf,
Lol without mentioning any competitors, you will find the majority of small local firms have hugely more enthusiastic/knowledgeable members who know what they are doing more so than huge company's like the one you mentioned who don't care about the quality of there work.
So many boards struggle to run the 8350 with bad power delivery :/
I'd love to SLI in the future(2 years), two 970s would be crazy.
I've only got a stock cooler but when I get new mobo i'll get new Case, SSD & Fan.
I will probably clock to 4.6 if i really need to if I eventually get this running properly.
To invest into a decent new cooler and an expensive mboard am3+ you really must get your fx8350 to 4.8-5ghz otherwise you are chucking £130+cooler down the toilet, when cheaper components like a mid range cooler and the 78lmtusb3 will get you to 4.5ghz with ease, or even Intel is a better solution for that money.
You need to look at games you play to see if amd is worthwhile investing into or if intel is.
For £70-£80 then you have the m5a97 evo r2.0, or the gig 970a ud3p.
The msi 970 gaming and asock fatal1ty boards don't have llc so it can hamper overclocking.
For £100-130 you have the gigabyte 990fx ud3 or sabertooth.
I'd buy the sabertooth but, I wouldn't buy a sabertooth today, I'd invest into z97.
To swap to intel is like £500 after parts & installation. a lot of money after just spending around £400,
Gonna need a new case, fan, ssd (install OS on there) motherboard & £250 CPU...
Is it really worth it?
I mainly play CS:GO and Total War..
Couldn't I just get a sabertooth am3 & a £30 cooler?
So as I've read previously, any board with "990FX" on it is mostly compatible? Is that correct?
No !
Dude, why didn't you listen to me when I first told you that this board is not compatible?
