Any chance of that R15 that you were going to run last week? Cheers...I will run R15 tomorrow.
Ok will look out for it later on.I ran it when I tested power draw. But did not upload the screens. Can do that tomorrow. I am sure it was 730-740pts.
Cinebench R15 2500K @4.4 6400 @4.4 Change
OpenGL 96.32 148.47 +54.1%
CPU 591 727.8 +23.1%
Single CPU 153.2 188.2 +22.8%
Unigine Heaven 4.0 2500K @4.4 6400 @4.4
FPS 115.16 116.26 +1%
Score 2900.4 2929 +1%
Min 35.66 38.6 +8.2%
Max 237.38 243.3 +2.5%
Firestrike 2500K @4.4 6400 @4.4
Score 9561 10109.6 +5.7%
Graphics Score 11857.6 12151.6 +2.5%
Physics Score 7954.6 9902.4 +24.5%
Combined Score 4448.8 4536.6 +2%
CPU-Z 1.74 2500K @4.4 6400 @4.4
Single 1671.8 2238 +33.9%
Multi 6487.4 8739 +34.7%
GTA V 2500K @4.4 6400 @4.4
Min 34.27 39.28 +14.6%
Max 110.18 132 +19.8%
Avg 76.33 83.66 +9.6%
Shadow of Mordor 2500K @4.4 6400 @4.4
Min 49.84 51.97 +4.3%
Max 86.11 87.00 +1.0%
Avg 67.37 68.87 +2.2%
Tomb Raider 2013 2500K @4.4 6400 @4.4
Min 47.7 46.9 -1.7
Max 84 85.2 +1.4
Avg 65.74 65.66 -0.1
right now I'm having a really big problem with the motherboard, If I restart the system then the PC will not post, I have to do a hard shut down and then start the system up again for the bios to post.
Can you help me with this or do I have to Rma the motherboard, The problem is still there with everything a stock settings as well.
Decided to replace venerable 2500K @4.4 with this bundle (+Thermal Grizzly
Kryonaut, Fractal Design Define R5), did some benches before and after (avg of 5 runs).
Reused parts: Gigabyte GeForce GTX 970 WindForce OC (361.43) @ 1920x1080, 250GB Samsung 840 EVO + 4TB Hitachi Deskstar 7K4000, Soundblaster Z & EVGA 850 P2. Win10 x64.Code:Cinebench R15 2500K @4.4 6400 @4.4 Change OpenGL 96.32 148.47 +54.1% CPU 591 727.8 +23.1% Single CPU 153.2 188.2 +22.8% Unigine Heaven 4.0 2500K @4.4 6400 @4.4 FPS 115.16 116.26 +1% Score 2900.4 2929 +1% Min 35.66 38.6 +8.2% Max 237.38 243.3 +2.5% Firestrike 2500K @4.4 6400 @4.4 Score 9561 10109.6 +5.7% Graphics Score 11857.6 12151.6 +2.5% Physics Score 7954.6 9902.4 +24.5% Combined Score 4448.8 4536.6 +2% CPU-Z 1.74 2500K @4.4 6400 @4.4 Single 1671.8 2238 +33.9% Multi 6487.4 8739 +34.7% GTA V 2500K @4.4 6400 @4.4 Min 34.27 39.28 +14.6% Max 110.18 132 +19.8% Avg 76.33 83.66 +9.6% Shadow of Mordor 2500K @4.4 6400 @4.4 Min 49.84 51.97 +4.3% Max 86.11 87.00 +1.0% Avg 67.37 68.87 +2.2% Tomb Raider 2013 2500K @4.4 6400 @4.4 Min 47.7 46.9 -1.7 Max 84 85.2 +1.4 Avg 65.74 65.66 -0.1
Definite CPU improvements, GTX 970 looks to be already limiting some results on 2500K, 6400 should do well with next gen card in 2016.
CPU stays much cooler than 2500K, <50C after 1 hour prime95 (reported by AI Suite 3/HWMonitor), can also feel exhaust air just isn't hot. Brocken 2 seems to be doing a great job cooling, also very quiet.
Only issue so far was default Windows sleep setting, causing system to become unresponsive when it goes to sleep and hard reset reqd, turned this off.
My basket had been up to twice the price of this bundle, but as OCUK guarantee the overclock and using existing sound card, decided no point me spending more for gaming, saving it for nice next gen GPU.
Thanks!![]()
