I like the M.2 heatsink. Completely pointless functionally, but looks tons better than the green.
My current build uses a green M.2, but luckily the M.2 slot is under the ITX mobo, so nicely hidden away.
Cheers mate, there's nothing bugs me more currently than manufactures using green PCB's, especially when like Samsung they'll sell you a more expensive yet almost identical model with a black PCB... They must know how annoying it is and know people will pay the extra to avoid the rancid greenness!
Oh yes, and sorry for the excruciatingly slow progress guys. With my proper job, IT tech support for every local too cheap to use proper tech support and feeling like crap the last few days, not much has been done. Still, I have found one potential time saver...
Reckon that'll do nicely as a base for mounting the Aquaero and Colour Work, even if it does need a bit of modifying. Not sure whether to put one in front of the other or the Colour Work on top with the Aquaero underneath, but it should be here tomorrow or Thursday so will trial it then, and hopefully have it all finished ASAP!
