- 27 Jan 2009
- United Kingdom
Those are nice looking cards, were those the ones that came with the free xplit? I was tempted to get one of them as it was a good deal.
I quite like the look of just red and black, also the thing would be huge with another fan!
Wow, the red/white colour combi of gpu's / mobo / ram + cooler is very nice mate, very nice indeed! Will look right at home in the S340![]()
A single 140 mm rad for 2x 970? The standard recommendation would be 1x 120 mm per block, plus 120 mm, giving a total of 3x 120 mm rad space. That's equivalent to roughly 2x 140 mm. So if you plan on overclocking, a single 140 mm would probably mean your loop would be running quite hot.Questioning if a 140mm rad would be enough to cool just the cores of both 970s...?? Just tried 3D mark and at auto fan 85hz increase on the core is all that can be done without throttling , will check to see the max it can do before crashing but no point in using till the cores are under water
Ooft. Loving this so far mate, I've seen a few builds with the turbo cards are they look the business. Colour scheme is spot on!
Think you can do that as standard on the Hue+? Good overview of all lighting options by hardwarecanucks:
Coming together very nicely mate, will look very cool with the Hue+ lighting in there![]()
Speaking of the devil, I just watched that video a few mins before hand.
In torn between have white back around with red chasing around or running GPU temp wise with white fading into a blood red at max temp.
Shame extra strips aren't out till end of next month
yeah there is almost too many options to chose from. Being able to have different colours on different channels could offer some amazing effects!Finally case came along with this badboy. Braided cables to come. Dry build start of next week I think![]()
Got my Hue+ the other day, really good kit but some of the LED's are not working and one strip was DOA![]()
picked mine up from ocuk, hoping all good but if not should be sorted quick .Great minds think alikeyeah there is almost too many options to chose from. Being able to have different colours on different channels could offer some amazing effects!
Looking forward to seeing it mate! Picked your cable colours yet?
Guttingpicked mine up from ocuk, hoping all good but if not should be sorted quick .
Will try it out tonight or tomorrow in my rig
