That'd be difficult since they use different sockets.im in a similar position at moment on one of my pcs. a 3570k@4ghz. its good enough for whatever it does but tempted to just stick a 5820k in.
Why did you pick the 6700k? Looking at these two chips myself.I've just installed a new 6700k system
Without going into the reasons why I didn't get a 5820k, from what I've seen today from a gaming perspective I don't think anyone's going to be disappointed with their choice. One of those situations where you can't loose![]()
The 5820k overclocks to a good 4.4Ghz. It is just as good at gaming as the 6700k, plus you get the extra cores for other stuff like rendering and the like.
Taking into account they are roughly the same price you would be a mug not to go with the x99 chip.
thanks for all the replies. I have finally decided to go for a 5820k build.
I have the itch and my gf will have my 2500k, my parents will have my gf's old PC. So nothing's going to waste. While it all works out for the better I want to get a decent i7 build ready for a GPU upgrade further down the line.
So... not sure if its better to make a new thread but I've been looking at options.
The main question I have is about a cpu cooler and clearance for the ram modules. I was looking at a bundle from OCUK but I'm not that impressed by the cooler options, I think id prefer a h80i/h100i or a Noctua NH-D15 or D14.
Good for you! Like many others I'd say the x99 build is a better fit for you. Will be interesting to hear your thoughts after the upgrade. Keep us posted!
I've been using a noctua d14 for a good while, its an excellent air cooler.
cheers! what case do you have with the D14? my next challenge is making sure i find a case that can fit a beefy cooler like the D14/15.
I'm liking the look of the Fractal Design cases.
Fractal cases are well liked. I use a Corsair 450d, its a fairly easy case to build in. I've heard the Phanteks Enthoo cases are awesome too.
Ye I like the clean look of the case, very impressed. I heard the Phanteks are good too but a bit pricey atm.
I think ill go for a 550/650w PSU. something like a superflower or EVGA supernova.
Still debating between air or water cooling, the sensible me says air but the fun factor says AIO water cooling like a h80i/h100i.
Those are good PSUs. The evga is probably a rebadged superflower, so you could probably go with whichever's cheaper, or matches your color scheme.
The h100i is probably the best performer, and the h80i in the same ballpark as a big noctua. As I understand it, all of those should be adequate for an overclocked 5820k.
AIOs look amazing, and make it easier to access your system after building. Whereas big air coolers are probably more robust owing to the fact that they have less moving parts. That wouldn't concern me though.
Ended up picking this one I think
Super Flower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - Black
Very frustrating to see so many things pre order or out of stock. Made picking a cooler and PSU annoying. Id prefer to buy everything from one place even though 750w might be a bit overkill.
Going with this cooler too I think
NH-D15S Dual Radiator Quiet CPU Cooler
The normal 2 fan version was out of stock ....
Turns out there is almost no difference though and you can just attach another fan essentially turning into the 2 fan version if you need to.
Looks great! 750w is over the top, but it gives you the option of multi GPU down the road
Someone might correct me but I doubt that cooler will hold you back![]()
