Mr Jones, its been a while!
It has been.Mr Jones, its been a while!
Making much better use of it than I ever did, ha! Nice pics
I have shot into the 3200, not found the noise troubling tbh.
Aiming for the 56mm f1.2 but it'll be awhile yet, going to enjoy my camera and lens before pushing for something longer and faster. Prime all the way as the lenses are so small!
Edit:
Also learnt a lot about the cameras auto focus, it's based on vertical lines. If you AF on anything that isn't contrasting off a vertical line, it hunts or fails. Interesting compared to phase focusing.
Always been impressed with the high ISO performance on my X-E2. Usually shoot in auto ISO with 3200 limit, and happily bump up to 6400 when necessary.
In Madrid for a long weekend and have used the 23mm 1.4 exclusively. Superb lens.
Torn between an XT1 or a X100T.
Have Children so may benefit from a faster lens and focussing. Might take more pictures with the smaller setup however.
Anyone have any advise.
XT1 & 56mm £1105 inc cashback
X100T £700
Head says X100T, heart says XT1
X100T £700
just wondering, is there any reason he should exclude the XT10 regarding the latter as it would be cheaper?I have both the X100T and X-T1 with 56mm and for the purpose of taking pictures of your children I would have to go with the x100T.
My reasoning for this is because while the 56mm is a cracking lens, it's quite limited in
what you can do with it. The 23mm on the X100T is kind of fit for purpose for pretty much anything. It's also ridiculously lightweight and can easily fit in my jacket pocket and can go anywhere. The X-T1 with 56mm, however, is a LOT heavier and bulkier (compared to a DSLR it is much smaller though).
You really need to think about whether you are going to buy extra lenses in the future to be honest. And if you go with the X-T1, I would consider the 35mm f2 over the 56mm as it would be a more useful focal length in general.
If you are on the fence then it's probably going to be a good time soon to pick up an X-Pro1 or X-E2 for a good price as people will be upgrading to the new models.
I am honestly so impressed my Fuji's firmware updates.
I knew the XE2 was getting the better focus from the XT1 & XT10. But I was not expecting them adding an electronic shutter option among other decent updates! Its pretty refreshing to have a piece of technology you bought not be instantly forgotten about by the manufacturer. Im looking forward to the 4th of Feb
http://www.fujifilm.com/news/n160115_07.html
