Were are people buying worktops from?
Im after a 1.7 meter piece of walnut.
Probably ebay but any kitchen shop should be able to supply them.
have seen £100 up to £300+prices seem to vary wildlyhave seen £100 up to £300+
have seen this one at Ikea link
i need it to fit a 170cm gap so would only need a trim, might fit in the back of my car too.
Should have a nice 65cm x 16cm shelf there.prices seem to vary wildlyhave seen £100 up to £300+
Prices can vary as some will be 'rustic' which is a mish mash of different coloured random timbers and some will use more uniform coloured, hand picked timbers.
The one you have linked to from Ikea is veneered chipboard instead of solid walnut, which is why it is cheaper. That's not to say its a bad product though, it has a fairly substantial 3.5mm veneer, so should last many years, if not forever if looked after.
it will only be a pc desk, so should be good enough for my needs i think.
How did you make the speaker stands please? Need a solution for my desk.
Boner9: What desk is that? And where did ta get it from cheers
