With the paragon levels do they get shared between the alt characters?
each character has its own paragon level so it will only apply to the one you are currently using
When u re roll a lower lvl legendary when your chara is lvl 70 the legendary does not become a lvl 70 legendary. Also if u kept an older version of a lvl 70 legendary which doesn't have a legendary affix in the hope that u re roll it in the new patch to have new affix, that doesn't work either
GeForce Experience?
Trying LoN garg with only 4 ancient pieces and it's still powerful as hell![]()
http://eu.battle.net/d3/en/profile/Qlimax-1320/hero/7397057
My season barb so far... I call it the 8 skill barb
1. Leap (also does earthquake)
2. Ground Stomp (also does avalanche)
3. War Cry (the dodge one)
4. Battlerage (15% damage)
M1. Ancient spear with boulder rune
M2. Whirlwind (Bul-Kathos set bonus)
EDIT: Earthen Might is main fury gen press 1 and 2 should max out fury then SPEAR to finish (M1)
EDIT2: Just waiting for Lut Socks for more leaping! (ignore my cube stuff for now its just temporary until I find what I need for it)
I started a WD on Friday, got to level 50 and then had to spend all weekend painting. Now I've decided I want to be a DH this season. Net result I'm looking to scrounge a boost tonight from sometime after half past six when I can log on. Any willing volunteers greatly appreciated.
If you need a char boosted, or anyone else for that matter. Add me at Buzzlloydyea#2294.
Sure thing but i didn't say a lower legendary could be rolled to a higher level one. Ballad asked that but I just answered what I knew which was a legendary can reroll stats via the cube.
I'm not sure how I feel about taking my existing barb back into the season, just to continue his played time... Are there any other advantages?
Five items done so far with level 60 gems, so an extra 1500 strength on my dude. It's definitely noticeable. Do a few more to night and maybe I'll be 13/13 by the weekend. Might need to farm up some more red gems. Anyone have a good plan for farming gems, other than the obvious thing of wearing a broken crown with a ruby?
