It was light hearted banter from your Evo thread where you changed your mind constantly....
Evo thread closed
Bit weird that the mounts for the bonnet struts are there already. Do they come as standard elsewhere i.e. the USA? Are you going with new wheels? Made any decisions yet?
Evo thread closed![]()
Gotta burn these tyres up first, but I have two wheel designs I like a lot in mind.![]()
Looking great Gibbo!
Silly (perhaps) question, I assume any heavy modding will invalidate the new car warranty, if this is the case, are you minded to hang fire or just think **** it and mod away?
And your reputation sealed in these parts, I hope it was worth it. :/
Have you used line lock yet?
Given your track record over the past few days it was a very valid comment. Do you actually own a car that requires Gibbo to fit a supercharger to compete against?
i've just brought somethnig.
you wont see anything on the Evo Forum eitherI DO NOWi've just brought somethnig.
Oh dear mals been on the acid again
It's bought ffs
Of course throwing a Whipple or Roush on them gives you a 10s car if you can launch it.![]()
My drive to work is normally a 20-30 minute affair, this morning I took a detour and took a good hour, dry roads, finally time to unleash the car a bit more. The bushing insert I fitted yesterday I do feel causes NVH, not much but enough to the point I shall probably remove the bushing insert and just keep the uprated mount.
The car, the engine is totally awesome, huge torque between 1000-3000rpm and after 3000rpm it pulls like a train to 7000rpm limiter. The gearbox well I think you all know I like it.
Handling, its got grip, surprisingly more than I thought you really can get on the power pretty early, certainly earlier than the M3 surprising considering the extra power and torque this has. The dampers are fine under 50mph, but over 50mph the car just seems to get floaty, hit a bump or change lanes over a crest and it literally bounces in slow motion like a boat going over waves, its not scary or losing grip but the car in my view needs more high speed rebound as the dampers are not controlling things in the back of the car very well. Car turns in well, very well, fast direction changes and well its no M3 or 911, you can feel its size and bulk, you can certainly get it through a section of corners fast, but you need a very smooth approach to control the mass. In short the grip is excellent, the handling is OK, its no M car, I'd say it is more on parr with a 3/5 series with M suspension/wheels for handling and direction change. Where it wins over an M car is for traction, it has got grip and the LSD works very well I am finding. But the suspension as a whole just needs tightening up, it needs to roll a little less and it needs a slightly firmer ride with dampers with better control. Hopefully my suspension modifications will resolve these short falls and most of the shall falls are stemming from the rear suspension of the car, the front-end in my view just needs tightening a little, bigger roll bar, braces should sort that. The rear however feels rubberised, floaty and wonderous, I am sure it can be improved.
Still even with these downfalls, even if I had to live with them, I would still be sticking with the Mustang, because it has got real character and soul, something really missing from most modern cars these days and this car has it.
Oh now I've driven it in the dry and unleashed full throttle in 2nd gear upwards, its quick, I'd say its 911 quick, probably no faster though and probably a touch slower than M3, so yes it does need more power, to most people would feel over-whelmed but the whole idea of this car was to turn it into a 700+ horsepower monster after a years ownership, and now I can just imagine flooring it in 3rd with such power will be a true occasion, but I do absolutely love how this engine revs, for a V8 with so much torque it is very impressive that it revs so well.
Anyway work time!![]()
this is staying a secret until i get it homeyou wont see anything on the Evo Forum either
