Don't be, and you aren't. You're training, it's good you make these mistakes now in a controlled environment rather than out on the road.
I dropped my training CBF600 on the first day riding one. I was doing the same it sounds like, after some riding came up to the instructor and ended up grabbing the front brake. I now just think of that as the 'falling off at slow speed' lever.
Thanks JunglistE, after thinking about it I do feel much better about it now, and it is good to know that it isn't only me who has done it.
You don't realise how heavy they are until you can't stop it coming over. The bike was a Yamaha XJ6.
You'll be fine once you get back on, first time out on the road on a 600 I got serious target fixation and ran a blind corner so wide I was square in the opposite lane with a people carrier coming towards me.
Funnily enough I've never done it again, same when I first dropped my 125 on the road coming into a corner too fast panicked snatched the front brake and down I went and again I've not snatched the front brake since.
You learn from your mistakes, don't dwell on it and get straight back on don't give the "fear" time to build and eat away at you.
I used to do a lot of dirt jumping, free style stuff, and have crashed and hurt things many times but always managed to get back on the bike, I know it is different in the respect that it is a push bike, but the fact that I got back on it without worry, and only wariness is good.
This felt a little different as it was unexpected, and frankly I never thought it would happen. I do feel better about it, I am going on this Thursday to do my MOD 1 as a mock test on the 125, to get a hang of the stopping properly I hope to crack it and make it second nature before getting on the XJ6 again, so it doesn't happen again.
We are riding to Nottingham so 40 miles each way. So should give me plenty of time to get a firm grasp on how I should stop. I know it should already be at that stage, but for some reason i'm not, and that is what worries me.
I have spoken to my dad in the meantime, and he said exactly what you said. Don;t dwell on it, and get back on it and learn from it. I will be doing that, and I'm looking forward to getting out again, and this time I'll be a little more prepared.
No problem.
it's all part of learning, once you get back on the bike you'll stop worrying about dropping it and enjoy it.
have you spoken to the training school about getting the seat lowered?
I will speak to them and see what they say, it was odd, because it I sit close to the tank I can reach the floor not problems at all, but I find that the jewels get a bit squashed!
Glad it wasn't only me!
Just need to get back on the bike, and take it from there.
On the plus side, I got my CBT certificate, and my instructor said that it was well deserved, even after dropping the bike. He said that I have come on in leaps and bounds since I started. I'm not afraid to open the throttle on the 125 like before, which is a sign for the better, as I feel a little more confident.
Bear in mind this is after I dropped the 600. I did have a couple of bad stops, which if I was on the 600 I would have dropped it again, it is was down to using the front brake again, and not using both brakes, and using the back brake to come to a final stop, once the bike is stopped then put my left foot down, after getting the bike into first gear.
