- 23 Mar 2011
The long walk to the first mission objective put me off lol :/ maybe i need more patience just not feeling it!
Shoot them back?![]()
will the dark zone be a big part of the final game do you think?Try it and have a compare.![]()
I've probably spent 5+ hours in the DZ playing solo and never really had a problem. I've run across a few groups who were going rouge, but you can see them coming on the map so just keep clear of them.
Also there is more to the game than the DZ. You can match make with other people on the main mission.
The grenade launcher is literally one of the first things you get? It barely does any damage to players too.
in the DZ, level 1-7 play together, doesn't really mean anything, theres no level advantage to the pvp aspect, but they may well have better gear if they farmed enoygh DZ points.
I've yet to stumble into an underbarrel launcher, so i presume your talking about the tech tree skill. It wont one shot you (unless you gear is bad i guess) bnut it will hurt if they get it on you.
You can get by in the dark zone solo you just need a bit of patience and set up your perks. Use radar and health. If you start an extraction in a quiet zone then you're asking to get done over.
Go to an existing extraction, stay at a distance until it's close to arriving, see who's there. If it's just one or two people with gear (you can see the yellow packs under their rucksack), they probably just want their gear out, run in when they do and hook your gear on.
If it's a busy zone and there are a lot of people extracting and going rogue, wait til another extraction happens, and do your own on the other side of the map.
It's definitely easier in a group but you can go solo ok.
VI3CC7QUM1WAIf I pre order now. Am I likely to get a beta key for tomorrow?
So, The Division, after all the low expectation ranting from some - including myself - is it any good?...
I'll start by saying the graphics are infact very good, to get the most out of it I think you need to max the settings which I am lucky to do, at 1440 res and a SweetFX profile Im tinkering with the game does look stunning at different points in the game. Im glad to be proved wrong after the PC graphics debate as it means the game looks very polished graphically. Maybe after a few tweaks have surfaced once it is released we might be able to edge back towards the old E3 footage. Having said that, at times it really is eye candy and there hasnt been the 'downgrade' I was expecting. So for that, well done Ubisoft.
HOWEVER (lol), what does concern me is some of the other little things that could indicate a potentially shallow game world and fall into the same trap as Destiny. Will it have enough varied content to keep the fans happy, I think varied is the key here as it could just turn into another go here, grind through lots of enemies, reach objective, repeat affair. Something which I did find a very weird design choice was not being able to kill/harm human NPC's which to me lowers the world immersion somewhat. So why can we kill animals and not humans? Considering the environment is hostile outside the safe zones, NPC's should be able to get caught in cross fire when a fire fight breaks out, the player should also be penalised for harming NPC's but making them invincible seems silly.
Anyway, I recorded some gameplay and made a video called the Beta Journey, just something I put together today, unfortunately it dosent have the SweetFX Im tinkering with, I only had K-Putts at the time, more on that tomorrow. Check it out below:
, was the lack of NPC's in the DZ. We would be spending ages just wandering around as a group looking for something to do.
VI3CC7QUM1WA
