Just got my BETa key e-mailed to me now on the last day of the test! Downloading now might get and hour or 2 in before the beta finishes.
EDIT***
ooooh reading back through this thread seems like I'm going to struggle to enjoy myself playing on my own
Ok, UPlay name change to minimise confusion. New name is Tess-Lacoil which is more like my Battlelog id and the same as my R* ID
I will change it in OP for you.
Hmmm, Ive just done the sliding skid move into cover behind a barrier, not seen that before and figured it was taken out. I think it was shown in some of the old gameplay footage. I think I may of recorded it, I'll check.
EDIT: Yep recorded it, will stick it in my next vid![]()
Happens when you use the move between cover points move.
Same here marc. I just let the game auto detect and most stuff set to high, fps are mostly around 50-60 bu dips to 40's and 35 in a few areas.
I'm currently running on a single 290 at 3440x1440 and high and it runs well enough with some dips to 35ish, when the final release comes out and I can use crossfire I'm sure I'll be able to get high fps from the two cards on ultra.How are people running this on ultra with a single 290? Am I doing something seriously wrong? I'm on high settings on a 290, 8gb ram and an i5 2500k and 4.4ghz and it runs OK but in places it will dip to 35/40... I'm only using an old 60hz monitor but the fps drop is noitciable. Everybody else is saying the game runs ultra smooth.
The elite enemies are tough and they will kill you in a heartbeat.Decided to watch someone twitch stream the beta and the first thing I saw was someone unloading a full clip of an automatic in to a mob with multiple heas shots yet they didn't go down. The enemies seem less threatening than a bout of man flu which ruined the imersion and took away all sense of danger... On first impressions I think I'll pass on this.
@1080pIt's actually quite good, I can see myself purely camping drop zones, murdering players and robbing loot all day long..it's all I've done so far![]()
Yeah, I don't understand how people are claiming ultra settings. It's either simply not happening or we are doing something wrong lol
I'm using Ultra at 1440p, CA and vignetting disabled and normally sitting around 40fps ish, but having a freesync screen it definitely helps it feel a lot smoother than those type of frames would normally suggest.
Got my first gold legendary gun
Game looks so good at night in the snow 2560x1440 screenie
you lot enjoying it then? Shame I missed it this weekend with the lads but will definitely link up with you lot on release no doubt
