So how does PA/yesbets cope with in play bets? Obviously very volatile.
Was meaning I take it you have to find the best odds yourself, albeit with a few pointers? For in play I wouldn't want anything between me and the bookie/exchange. So not sure what the benefit of having PA is?The forum on PA is the best place I've found for in play info.
Am I alone in not bothering to record anything in detail? I just have a rough daily/weekly profit total in my head.It has made it all a lot quicker, what with recording all my bets and balances as well.
Bit of both perhapsMaybe it wasn't clear what I meant or I've misunderstood what you were asking.
Most of the stuff you describe sounds fine but also seems like it might foster a reliance on using a particular site in the long term. No incentive to get your head round things which would enable you to do it on your own.Perhaps its just me that likes the features, but it does seem to help me a lot in my matched betting antics![]()
So you could do that without Yesbets? That was what I was getting at initially.For in play stuff, I tend to just go to the urls and then just pick the best match at the time
What % extraction do you normally get? Over/under and correct score markets can be better if you have sufficient funds in your exchange. It feels slightly counter-intuitive initially but often what appears to be a poor match at higher odds will be better than a close match at low odds.I nearly always do the W/L/D market due to liquidity and odds
Bit of both perhaps![]()
Was meaning when it comes placing any bets in play when the odds are very volatile. xibinim had mentioned "a new type of odds matcher ... one specifically for fast moving odds/matchers just before the event".
For any other bets something like oddsmonkey is sufficient (and free). £23 for PA just seems poor value unless you need a lot of hand holding, but I'd happily be convinced otherwise.
Is there a guide or post anywhere that explains how the accas work for guaranteed profit? I'm probably searching for the wrong thing but can't seem to find anything that explains what to do.
I get the whole concept of matched betting, just not how you lay against an acca to guarantee the profit...
This should help you out mate.
http://www.oddsmonkey.com/Blog/tabid/140/post/life-after-opening-offers/Default.aspx
bet365 £50 risk free offer is back on this Tuesday for the Chelsea match, easy £30 to be made![]()
BTW B365 have their £50 in play offer on the Chelsea game tomorrow, guaranteed £30 profit!!
Sorry, but could either of you explain where the £30 can be made/guaranteed?
