I picked some 30Q's from Torchy which seem spot on so far! Usually use Samsung 25R's... Not sure if it's placeboo effect or just cause they are new but slightly quicker ramp up time I noticed too.
Ideal for those Mouth to Lung hitters I imagine, seem to be PG heavy... Free to good home'sDecided to go 50/50, 2x 30Q's and 2x HG2![]()
Bit of a random one, has anyone tried to change the LiPo in the mini volt? I'd love to be able to get 9 hour day out of it at 25-30w
Received my VTC Mini from Gearbest confirmed via Joytech's website it is indeed genuine, Really impressed with it feels great! Still need to tinker with builds on the Crius but it's okay perhaps 3MG in a tank isn't satisfying enough.
I bought a new Kanger Toptank Mini and have a question regarding the coils.
It has an Ni coil fitted - are these only for use with temp control boxes?
I'll probably use the RBA anyway - I found the vertical coils leak. Just wandered what the deal was with these Ni coils.
How long did it take to arrive? I ordered six days ago from Gearbest and it still says 'Processing' at the order stage.
Agree with Slinxy, the Mini Volt does not have room for a bigger cell and although its sold as a 40w, if you want to get a 9 hours day out of it you need to be running higher ohms and lower watts, i run mine with a Goblin Nano on it and a 1.3ohm coil or my Goblin mini with a 1.5ohm coil, both need less than 20w.
If you want better life you will need to get a bigger mod such as the IPV3 or VTC Mini or Cloupor 50w Plus, they are the smallest single 18650 mods going at the moment, the Cloupor being the smallest of the three and the VTC Mini having the best support for different wires should you want to do TC. There is also the Kanger Subox Nano to consider..
Managed to snag a new goblin mini v2 today, score!
Also ordered 500ml of nic from Darkstar. In the freezer it shall go.![]()
snip...
Looks like Myepack will be getting them in soon!![]()
Where from and how much dude?
__
