Haha, sounds like a bit of effort does that though buddy!
Gift certificates are issued immediately, if you do wish to go down that route
You guys seen the aromamizer rdta v2? A whopping 25mm of sexy by the looks of it!!
Gift certificates are issued immediately, if you do wish to go down that route![]()
They're great for mixing the eliquid.Done and dusted...Should be getting shipped tomorrow!
Fingers crossed they won't ship me those 2 vibrators I cancelled for the voucher
Try the Cleito.@70W with 80/20 Juice you get very good flavour and clouds but IMO my TFV4 with the TF-T4 head is better for flavour.
Anyway, a good tank but not the all singing dancing TFV4 beater people make out.
Have the subox mini myself, but I use the RBA instead of the OCC coils.
You're better off dropping the wattage down with the OCC as the wick uptake isn't the best. Down to 17-19w should see you right. The chemical taste could be that you're burning the wick a little, or the juice is just no good.
When I quit smoking, I was using sub-ohm coils and between 12-18mg liquids. A lot of people say it's too harsh to vape 18mg at sub-ohm. Don't listen to them, it's whatever works for you as an ex-smoker. It worked for me, and now i'm down puffing between 6-12mg as that seems to be my real comfort zone.
Good luck , and welcome to the cheap side of life!
Try the Cleito.
Now I admit this is very very gay, but a friend and I had a quick 'Vape-Off'. My Cleito at 40w on a 0.4Ω coil kicked out notably bigger clouds than his 8-coil TFV4 on 65w...
We then 'gang-vaped' the other friend, who actually is gay and vapes on a pink Curve Mini, heh heh!!!
Try the Cleito.
May have been higher. I dunno.You need IMO 80w and above for the bigger coils like the TF-T4 65W is too low,
For what it does, I am very impressed... I just prefer keeping it dialled down to save my meagre juice money!Will defy try a Cleito and the coils seem very well priced. Does look a very good tank![]()
Jeezy, the only coils that don't last me longer are my EDV Nautilus Mini ones, which are pretty much in constant use. Most people get 3 or even 4 weeks from them, as is.quite expensive but 2 weeks out of each it's not too bad,
