Plate on yours looks better in that picture IMO.![]()
Mmmmm might just refit it then, will have a good look tomorrow in daylight.
Mmmmm might just refit it then, will have a good look tomorrow in daylight.![]()
Plates too big, change it back....too much yellow space![]()
When are you planning to respray the wheels?
We're a needy bunch![]()
I don't understand you comment about the oil specs
I think the wheels on it look pretty good. They contrast with the silver trim. I'm not a fan of the everything as dark as possible look on everything at the moment tbh....
I am not, they are staying as they are, just buying new wheels instead.
Its OK, does not matter.![]()
The ford spec is tested in ford engines and approved by ford. The other stuff is pretty irrelevant and you've gone for a pretty average thing there.
Just seemed odd after how much you were concerned with the Porsche
Ford use Millers?!
