It also don't have the boy racer image of a Focus either
That said, I don't mind really, it's a step above my Yaris, and double the BHP.
Sleeper with 270-280bhp is pretty awesome!
And that 5 pot sound...
I find it really hard to believe that an exhaust on a yaris would be so hard to find...
I'm hoping the dealer to I'm trying to take the car in trade will be as clueless!
1.8? I didnt think such a thing existed!
If anyone wants a crack at finding an exhaust for it, the plate is CK08 CBV.
That's where you're going wrong - you're using the reg to try to find the exact part. You'd be much better off taking it to an exhaust fabricators - chances are they'll be able to weld it for far less than a replacement part. I had exactly the same issue with my MR2 where all the parts sites couldn't find anything through the reg, I just went to Maidstone exhausts and they charged me £40 to weld it.
No matter what the problem is with the exhaust, can't you just get a mechanic to weld a couple of small plates over the holes?
Yep, they're not bad at all. Certainly a warm hatch at least
http://www.parkers.co.uk/cars/reviews/facts-and-figures/toyota/yaris/sr-2007/
What about Renault, having standard across-the-range 20" wheels on the new Scenic??Smart move by Toyota that, putting a very expensive tyre size on a Yaris...![]()
I's that a Hilux to us in the UK or a different model entirely?
It's technically a Hilux, yea
Love it!Picked this up the other day. 1977 Chevrolet Corvette. 5.7 litre 'small block' V8.
