congrats on the job Nick, when do you start??
might be able to get a session in before you do, should be some Plaice about atm...
(and approval from the mrs for some cheap trips).
(€35
)Unsure yet - their process can take 6 weeks.. so I have time atm(and approval from the mrs for some cheap trips).
The wall is still closed at the moment. I have my cheapy beach caster(€35
well you've got the dates for when im at Selsey so il email you before i go to see if you want to pop down
tell Mrs car failed MOT
spend £200 on fishing gear
profit
Hehe I wish.. Just got the formal intent to offer, know the details and timescales.
Just put it this way.. they take long enough for me to go fishing - almost to the second holiday![]()
the 2nd holiday is now the 3rd holiday, id booked another
il email you....
Those two break waters would be a good location.. if there's weed/sand or rough ground then they're usually about as they have somewhere to hide/hunt.
The rods on my mind at the moment are..
* DAM EGI rod - it's unto 35g so lighter than the spinning rod I normally take along - would work from boat and shore.. but the spinning rod would work probably... although the spinning rod I have is 20-50g and it's not too happy with 20g..
* Kenzaki 12/20 boat rod.. 3-piece is stiffer and would do wrecking and inshore boat.. although I have something that fits this range....
* Supercast second hand - realistically my time using something like this would be limited when working.. probably just when I go to france with the father-in-law.
on a large (spring) tide all the rocks that make up the breakwaters are exposed, and inbetween the breakwaters its quite a clean sandy bottom,
to my knowlegde the ground doesnt get rough untill you get round to the eastern side of Selsey Bill
I've got a Kenzaki 20/30 3 piece, Its an awesome rod. Will take big rays and Congers in a strong tide no problem. Its really light and nice to handle. Picked mine up from Poindexters in Southampton for £80. I've got another Diawa Proteus 12/20 which is great fun to use, the only issue I found with that is it struggles when you got over 16oz of lead.
There's a Kenzaki new model now with a kind of burnt orange colour on it, its look pretty nice
