- 18 Oct 2012
Cheers guys, only went with 0.6% nic any way, I don't need much.
So the lower the ohms, the higher the wattage, gotcha!
Might just be that their juice isn't great, I just grabbed a few flavours as part of the order.
Is there a certain PG/VG ratio that is best for this mod? I don't really understand how the differences affect things, and I won't be going the whole custom hog, this is just so I can smoke with my gf without having to have actual cigs![]()
Pg is thin runny and delivers the flavour/nicotine
Vg is thick gloopy and makes for creaminess and big heavy clouds
I personally like the heavier mix's, but i've found my current tank setup doesnt like thin stuff. Generally 50/50 is a good mix for most stuff, if its thin some tanks can leak but likewise too thick and it just wont wick quick enough.
Generally juice buying consists of buying a bunch of 10ml then getting more of what flavour/mix you like
