Not any more you can't (well not reliably) - even 3rd party software that blocks it isn't foolproof unless they stay on top of updates as well.
The old Device Installation Settings option changed to "apps and icons" and some device drivers will install through it any way regardless of which option you have it set to - not sure if its bugged or intentional behaviour.
GL with that in Windows 10...
Worked for me on my windows 10. I stopped the option to download and install drivers only windows updates auto download.
https://www.reddit.com/r/pcmasterra..._bugged_new_drivers_killed_my_gpu_and_others/
The ill informed strikes again. ****ing place is plagued with them.
Id be carefull, those settings can change with a background update from MS. Have a look at barnacules Video. Shows how even thought you specifiy the settings MS can still change them back. Sneaky and sly!
It kept happening with Windows defender, id turn that off and few days later find its turned it self back on. Quite annoying! I had to manually disable the bugger in the registry!
Are you still using Windows 10? your post seems past tense and the option for that has changed in recent builds and doesn't behave quite like it used to.
DDU also turns off the Windows Driver update the first time you use it.
Burning out graphics cards! That old chestnut, my arse.
It saddens me to see people poking fun at this. If people have genuinely had GPUs damaged because of these, they get my full sympathy and hope they can get sorted.
Careful guys it continues - http://www.techspot.com/news/38131-nvidia-19675-gpu-driver-burning-up-graphics-cards.html.
Andi.
I totally agree with you. However, it doesnt take long to have a look over the AMD driver forum thread to see why some people come into this thread when something like this happens to "Get their own back".
AMD users have been getting hammered for quite a few years and since i have been actively contributing on these forums there doesnt seem to be a level and fair playing field when people go on a rampant speight of trolling.
If Nvidia users do not like it when it happens then they shouldnt dish it out over in the AMD forum threads....Please dont ask for evidence....it's littered all through every AMD thread on OCUK. You only have to look at the Crimson driver release for that. A very similar issue in fact.
I do hope that no-one has had a card die as that would be gutting. GFX cards cost a small fortune these days and no-one can afford for one to just die because of a driver issue. I wouldnt wish it upon anyone regardless of manufacturer.
If we all want help from these forums then we must clamp down on the trolling from everyone, not just some. I certainly have had enough of it and have been suspended once...so I am not saying I am whiter than white in this matter either.
I hope you all get your drivers rolled back or patched forward (A patch was released very quickly, I believe) before anything serious happens.![]()
