- 31 Jul 2010
- Stoke-on-Trent
Has anyone elses performance gone to **** since the downtime today? Barely hitting 20fps now.
How is this game? Worth playing?
I'll have to have a closer look at the map, I was playing around with it for about 5 minutes before I gave up and decided to walk all the way to each of the node managers.
It was fun up til the Orcs.
Got 2 chars up to that level (quests are level 28) and burned out on both right there. Game goes into grind overdrive at that point but with elite mobs that take ****** ages to kill, and that's not for me.
As said there are a lot of other good things in the game, but not enough that's truly original. It feels the same as any other mmo, just slightly different.
Didn't have any issues with the normal orcs. It's the elite mobs that are a pain, and when you've gotta "learn" about them... you know the score, it takes ages killing one let alone many. One more level won't make a difference.Go to the Orcs after you gain another level, you should have been at the monastery until 29-30 then went to Orcs.
I did the same thing on my Ranger, kept grinding on mobs that were higher than i should have been which made the game feel horribly grindy.
Edit - use this guide to get an idea of what you should be grinding on at each level http://2p.com/41167276_1/Black-Dese...Guide-Level-1--50-in-15-Hours-by-cindyhio.htm
