- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
If I didn't have the edge, I would have felt cheated tbh. It seems rude not to get it imo.
but what are the differences between S7 and S7 Edge? I have an LG G2 and I really like the size so the S7 is standing out. Is it just screen and battery, hardware otherwise the same? Cheers![]()
So is everyone satisfied and glad they got the S7/Edge?
It's certainly prettier.... but I need to go look at them both and literally get a feel for them to see if I will be OK with the size increase![]()
Which MicroSD card to people recommend... better to go with a 200GB with slower write speeds, or a 128GB with faster write speeds? I guess as it's mostly going to be a media card the slower speed should be OK? I doubt 4k recording is high enough bit rate to be too much of an issue?
I'm actually wondering if I can return it and buy the standard instead, anyone know if I should be able to, I know people do this a lot with Amazon but not something I've ever done, should I be okay to do this with Samsung direct?
You should be fine: https://samsungshop.zendesk.com/hc/en-gb/articles/205154501-What-is-the-returns-period-
"You may cancel the Contract and return your products for any reason within 28 days of the day you receive the Product(s)."
You always have DSR to fall back on anyway....
4K is about 50Mbps - a class 10 card is 80Mbps+
I's stick with Sandisk or Samsung.
Would have been 100% easy with Amazon - Samsung....not so sure. Can only try.
What's Amazon's return policy?
Just got another update of 3.32mb for Edge app or similar.
I got a Sandisk 128gb Micro SD card from Argos for £29.99 as they on offer for whoever was asking.
Mine is going back to mobiles.co.uk for an exchange today as the camera is faulty. Love the phone and hope the replacement doesn't have any issues.
What do we reckon? Location history with wi fi and Bluetooth scanning on or off?
