Hi guys,
snip...
This is worlds away from those crappy ecig lites! Think I'm going to like this, looking forward to learning more!
Noobs guide.. yes they are exceptions to everything.. but this is to keep it simple.
Different material has different resistances and different temperature points without getting all science it is important health and safety wise to make sure your on the right mode. The only exception is some stainless steel which can be used in SS mode for temp control and wattage mode.
most people vape round 4.2 volts which is a freshly changed battery, give or take. max voltage on a single battery should really be 5 volts, on certain tanks they will flood if you vape at too low, the minimum should be 3.6v, normally battery charge to stop flooding.
back in the days, you would build a coil to suit the way you vape and work out the wattage from there. build/use a 1 ohm or 0.5 ohm coil, to keep it simple.. start off low and then turn the power up slowly. till it matches your needs. (I tend to build a 0.8ohm for mtl and 0.4 for dtl, is so I can throw it on a mech).
for temp control.. set you mod at the middle power, unless the middle is more the 50 watts, in that case set it to 50 watts.. then start the temp control at 380 and then turn it up to match your vape needs... The burning point of dry cotton is 420, but cotton is never 100% dry in tank, so it's ok to place it higher.
All cotton has a breaking in period, if you start a new coil/build off at low point then start to turn it up... remember to prime all coils first, some don't need it but it's a good habit, this way it will last longer! if you can taste burnt and need to turn it down, it normally means the cotton/coil needs replacing.
Don't fill to the max, leave about 1/10... it is worth turning the tank upside and back to normal a few times, the air pocket should move and you should get bubbles, if you don't you will have an air lock/steal and will have wicking issues, open the tank and reclose then try turning it again...
learn battery safety!
Use good batteries.. on a wattage mod, look at the max amp draw on the chip that it has.. if it's an unknown chip, work it out using ohms law, with the minimal coil it can fire, at the maximum wattage or max wattage / 2.5 is a rough guide.
learn ohms law!
Quick maths work out...
Voltage / Res = Amp
Amp * Voltage = Wattage..
learn ohms law!
Voltage / Res = Amp
