It was set to race mode![]()
Sorry had to laugh at that, can imagine you typing that like you are telling a parent you have done something wrong when you were younger and wait for the wrath!
No I didn't, I was rather lucky as cars usually pull onto the roundabout into the outside lane, there was a car waiting but he allowed me to pass.
Use the mode switch, but the image is a US car, on UK cars they are opposite way round.
Mode options:
Normal: Lazy throttle, ECS only marginal slip, TCS some spin, normal steering weight.
Sport+: Normal throttle, ECS more slip angle, TCS more spin, sport steering weight.
Race: Sport throttle, ECS lots of slip angle, TCS off, sport steering weight.
Wet/Snow: Very lazy throttle, ECS no slip, TCS no spin, comfort steering weight.
I use normal for only greasy or extremely heavy rain.
Sport+ I use for wet conditions and Race I use in the dry.
Sport+/Race transform the car, make it feel a lot more awake compared to the default normal mode. I always set steering weight manually using the other switch simply as in sports mode it has less feel due to artificially adding more weight. So I select sport+ or race and then I put steering weight back to normal using other toggle switch.![]()
I definitely have more respect for it now, I came from a 170bhp diesel so its a bit of a step up.
MW
lol, guessing a FWD diesel at that?
Take it gently and leave the nannies on otherwise you're going to break things.![]()
It was and I never dared turn off the traction control
The first thing I did after messing my pants was turn it to normal mode
MW
If money is no object get some great wet summer tyres on the stock wheels like F1AS2/3, Pilot Sport 4, Conti 5P/6P, Rainsport 3 and make them your winter set wheels/tyres. Then buy some nice shiny wheels and fit MPSS.![]()
Are the tyres going to be enough of an issue that I'll need summer and winter tyres or will I be able to use an all-rounder ?
£750 for 4 new MPSS, would be cheaper than a crash
Ha, buying new tyres is a bit extreme when you could just drive sensibly...!![]()
