I got a pair of GP4000Sii for £43 the other week from Sportpursuit when they were doing 20% off.
Awesome deal! Well done! Nearly got around to fitting mine on the weekend but ran out of time.
Just checked to see when my Garmin is due and its not till Friday !
That's some slow posting
Sheesh, where did you order that from? Canyon?! Lol
This is why I'm glad that Wahoo has at least launched a potential challenger.
Yeah I hope they continue to develop, same with Cateye really as both are brands I'd trust and happily use in place of Garmin. Garmin need a wakeup call with their pricing, features and reliability! Until now they've been able to somewhat dictate the market...
These will be with me tomorrow -
http://www.wiggle.co.uk/fizik-cyrano-r1-carbon-road-handlebar/?sku=5360605612
Plus the seatpost.
Plus the bar tape.
Plus the matching stem that I won on eBay for £40.
Will I float up hills and then snap all my finishing kit in the sprint?
Who cares, you'll look awesome with matching finishing kit, that is winning regardless of position!
Related note, did a good 4.5 hours of maintenance on mine yesterday... Fizik
bar gel pads &
bar tape now fitted. Looks awesome with my Arione too. Went with the gel pads to try and reduce some of the numb/sore hands I occasionally experience. Bars now feel huge! Check the 'lip' from tape to bars!
Not the easiest job and only the 2nd time I've done brand new tape. Texture feels great (I came from a rubbery/corky type before).
Also replaced all gear & brake cables along with all outers & refitted mudguards in preparation for this weeks commuting (boo). Full clean & relube (was going to leave this until later in the week but hard to ignore road dirt when you keep getting it on you when trying to do other things!). Reindexed gears and refitted my inline adjuster. RD cable was long overdue as indexing is now better than it has been for months! Sweet!
Ran out of time slightly as was going to switch out my Conti 4Seasons for the new GP4000Sii's but that can wait a week. Noticed quite a bit more damage to my rear than I was expecting, surface of the tyre 'cracking' lots too but they're still going strong. Might not get the 2 winters out of both of them like I wanted...
Repaired my damaged shorts by restitching them, quite impressed with my handiwork as I'd heard horror stories of stitching lycra before and previously used pronty patches. As this damage was over a seam I decided to try sewing first as can always pronty them again/afterwards.
During:
After:
It 'sticks out' as this is on the outside with the pad on the inside, couldn't have it sticking inside without unstitching a big area of the pad which I'd then need to restitch...
