@Hedge you can use a DK2 with it btw.
Bought this again but waiting til my G29 arrives tomorrow before playing
Anything I should do to get it G29-friendly or is it ready to go out the box with default settings?
should be pretty decent on default. ingame its preference. there will be configs though on steam. maybe try a g27 set up as will be similar.
frankmcg make sure you install the g920 software. also dont put wheel in until it tells you to.
did a new PB with my pug 205 on fferm wynt last night
was laughing because a guy i watch on twitch was playing/streaming with the pug after a hr he was dripping with sweat.
they should make prisoners play straight for 10 hrs with pug they wouldnt commit a crime again![]()
I've just upgraded from a DFGT to a G920 (going cheap!) and found the force feedback is way less severe now with the default settings. Anyone who's done a similar upgrade found the same thing?
Also the brake pedal only goes to 40% on the calibration settings which seems odd? Other 2 pedals go to 100%.
Just like us 95% of racersWas tempted by one, but I have no cockpit to mount it. Just a chair and desk.
Just like us 95% of racers![]()
