- 7 Jul 2008
- Newcastle upon Tyne
What setting were you using?
Looks like your into your cars as well
Yeah, it's to keep power consumption and heat down when extra power isn't necessary. I think you can turn the feature off in Nvidia control panel by changing "power management" to "prefer maximum performance" from "adaptive", though I wouldn't recommend it.
The only way to hit the high clocks is to change res to 4K in some games then it boosts to 1540. When it's doing its dynamic clocking it's running at about 1160 or lower depends on the game.
Crikey. Just installed a G10 with H55 and my card is cold. Did go about 42c in a 10min run of Valley. Normally it was be 75ish..thats 33c off!
ok 48c max with pcars fully maxing my card.
astounding.
Guys, I have purchased a second 980ti for the set up yesterday - the Gigabyte Extreme waterforce edition. Everything is great performance and temp wise but I can hear a water flowing through the radiator on odd occasions.
It scares the **** out of me as at first I thought it started leaking. Cold this be some air in it? Is this something I should worry about?
Card sits in top slot with radiator above it in a rear exhaust slot. Pipes are at the top position of the rad. Should I turn upside down?
Emailed gigabyte but no response due to bank holidays.
Card was new but had no warranty with it so a bit worried.
Nice temps!
I'm happy to sacrifice some heat for low noise performance so my strix is perfect for me.
I doubt temp is 50c at full load unless you live in Antarctic.
Im sick of overclokcing for the time being, I have tried multiple bios' from places like this http://www.overclock.net/t/1411500/official-evga-classified-k-ngp-n-owners-club but none seem to be 100% stable for gaming. Im just going to flash back to my standard bios and leave it at stock i think.
It annoys the hell out of me that you can buy what you expect is a premium product and both (I RMAd the first 980Ti classy because it throttled at 66c all the time) cannot overclock as well as cheaper or even reference models. Companies should properly test to see what the highest overclock is then sell the crap ones cheap and the good ones expensive
