Unigine Heaven 4 benchmark
very nice! those copper heatsinks looks the business!
here is mine
[*]Score 5299, GPU 780Ti @1202/1875, CPU 5960X @4.8, JR23
I'm very pleased with this score and somehow I think there is still more gains to be had and much tinkering to be done. Quad SLI GTX780Ti Lightnings at 1202MHz core 7500MHz memory with an i7-5960X at 4.8GHz, all under water.
JR
JR
And on the scoreboard.:)
I think this is the max I can do without setting max fan speed and adding more volts. Need to check with multimeter what the current voltage actually is first
2775
1520/2108
Hi All, I'm thinking I'm doing this wrong.
When I run the bench at 1080 I only get a score of 1540, but when I run it at 1440 I get 1396 which is more what I'd expect. I suspect that max FPS is being capped somewhere as the max FPS is the same on both at ~63.
Vsync is off by default in the NV control panel - what am I missing ?
4770k @ 4.3
980ti at 1225/1853
4770k @ 4.3
980ti at 1225/1853
I imagine you are limited by the [email protected]. Push for 4.6ghz+ and it should improve vastly
I'm afraid I can't is a poor CPU. Even 4.4 will crash at 1.3v+
That also doesn't explain why 1440p is about right, but 1080p is way below what it should be.
Are right, thats not good then.
CPU is required for lower resoultions if you wish to increase FPS. I hate the word but the GPU is 'Bottlenecked' by the power of the CPU
If you have a 1440p native monitor I would expect you usually game at this res. 1080p gaming on my 1440p monitor looks terrible.
I would put money on my 1080p score dropping right down if I clocked my i7 4790k back from 4.7ghz to 4ghz
4770k @ 4.3
980ti at 1225/1853
V-Sync or G-Sync turned on ?
Scoreboard updated.:)
No, I've turned V-sync off in the NV control panel and the monitor doesn't have g-sync.
I can't think that a 4770k with a small OC would bottleneck a 980ti ? I think something is capping the FPS.
