same sources which are telling you it will have GDDR5x and launch at computex.
Thought so
Love this place.
The problem with these theories is that 980ti is good seller for nvidia and 28nm being so cheap and reliable to manufacture it would be madness for nvidia to intro slightly faster version of that card with new name and on quite expensive new process which still yields bad. Why would nvidia go for lower profits to just introduce something new.
But if new cards were significantly faster, then it would make sense to intro them.
Thought so
Love this place.
How will 1080 release at summer if GDDR5X mass production starts just then?
Does this mean that we can expect a Titan X replacement later on in the year?
Yes, No, Maybe.
Hopefully it will be better than that. We had the same if not better with Maxwell without a die shrink. Core count seems low on those specs for the 1080 and 1070. Surely it is more likely that the 1080 will have around 3000 cores.
The 980 had 2048 cores compared to full maxwell having 3072 so why would the 1080 have 2048 cores compared to big pascal having 3840 cores?
You would have thought the 1080 would have around 2600-2800 cores.
One of the sources for a lot of the rumours was claiming 6144 shaders on GP100 even right before GTC![]()
Sony did exactly the same with the PS2 when Sega had released the Dreamcast. The Dreamcast was a good console, but Sony had drip fed "Rumors" to the public which made them hold out for the PS2....and it worked.
The PS1 was so cool i ordered mine straight from Japan for a cool £900 back in 1994 with Ridge Racer and Tekken. People in the UK hadnt even heard of one for atleast 12 months after (no internet back then only Grey import) and it made it even more desirable to have one. Not to mention the PAL UK ones ran at an awful stutterfesting 50hz instead of NTSC much smoother 60hz. Same as the N64.
