Just switched to BTU from VOD, instantly got the update, feels good. Smart switch made it easy to deal with the reset of data.
Wonder if it's possible to go back to VOD if needed? I read on xda it might not be.
That's you going from Vodafone firmware to Unlocked right? I've also got VOD firmware on my device and currently on G935FXXU1APB4 with Feb security patch.
All these updates and we're getting none of it..
Last time I used Odin and tinkered with my Samsung was with the S2, can I avoid any data reset if I want to load an unlocked firmware?
The most I would ever have on my pwn phone is the Spigen Thin Fit really, everything else is just a no no!
