- 30 Nov 2011
I meant cases of product, like boxes of 10, not PC cases
We never sold singles of anything
Hi, is there any ETA on the these? I have pre ordered one just wondering if any light can be shed on estimated delivery's.
Thanks.
I'm a bit confused...the Fury is lower spec than the Fury Nano, so why is it that people getting so excited about it being at this price![]()
Yes but that's because of the at stock setting the Nano throttle the clock speed by design due to keeping the power-consumption below 175W; up the power-limited, and the clock speed would stop throttling (provided if you can keep the GPU temp below a certain temp with a good airflow case).could be down to the cooling but benchmarks i have seen puts the fury slightly ahead of the nano
Nano has the potential to be like 95%+ of Fury X performance, provided that the clock speed doesn't get throttled due to voltage restriction from the power limit or too high temp.So the Nano? is it as fast as the Fury X with tiny? Might get one and watercool it.
I wouldn't do it even for my single 290xcool...
Might sell my two 290x and grab a nano... No games can run crossfire anyway so might aswell lol
As tempting as Nano is, I don't think it is worth upgrading to a 28nm GPU graphic card this point in time. Also the 4GB memory "may" become a limitation, especially if going VR.
I may be getting a 4K HDR TV sometime in the future as well, so I would definitely wait for next gen.
Im not, i don't think 4GB is enough, you would be mad to buy a card with only 4GB now, thats just imo.![]()
Why would you buy a Fury X and a block, when you can get a Nano and a block for much cheaper, which you can then just whack the paltry 50MHz drop on the core back onto![]()
By the time 4GB HBM isn't enough, we will likely have way more advanced cards anyway and looking at 4K/8K resolution. This price VS a GTX 980 which only has '4GB GDDR5' btw, is a great price.
