But the Ti denominator has only been used on the 780 Ti and 980 ti so not much historical data to go on. However, I'll be surprised too if the 1070 exceeds the performance of a 980ti - probably match it at a lower price point.
660 Ti , Ti isnt a new thing
I knew I should have clarified what I meant when I posted - I meant the top-end where a comparison is more easily done ,and a comparison we care about in the current part of the discussion![]()
The urge for the highest end has gone, says a guy with a Nano and a Skylake and you want to get a new 1070 and Kaby lake the second they are out..... really?
The Nano is the third tier card from AMD currently as the 1070 might be if the rumours of three GP104 chips are true. As for the Skylake i5 6500 that is number 10 out of 14 Skylake CPU's, of course not forgetting there is 3 more enthusiast CPU's above that.
Of course Boom you are quite right, what seems expensive to one might be cheap to another, spending on our hobbies is all down to what the individual deems it to be worth.
Take our beloved ex leader Spie, he spent god knows how much on top end Ferraris, Now I for one would never consider spending hundreds of thousands on a car, (not having a car licence helps that decision lol) but I wouldn't blink at spending a couple of grand on a bike. notice there is quite a difference between Spie's vehicle spending and mine, that is down to available income and personal preference. Not some universal this is expensive and that is cheap rule.
But the main problem is if the GPUs starting getting pushed up a tier at a time,you will be not paying £150 for a midrange gaming card but £250 and then £350 for a £250 one and so on.
Then you will find more and more people just buying a console instead or not really having enough GPU grunt since that £250 card is not really that fast,and we will end up with more and more console ports running at a cinematic 30FPS LOL.
Sports cars like Ferraris don't affect the pricing of the normal cars like the Fiat Punto or even an Alfa Romeo which are all part of the same company.
What we need is BOTH AMD and Nvidia to either come up with another 9500 PRO or 8800GT. That will get a lot of people to upgrade and means devs can aim for a higher minimal level of hardware on PC.
You can't possibly think that 1070 will match 980ti. There is no way NVidia would do that. Maybe it will match 980. But thats all you can get.
You joking so a shrink gives about 15% increase my god we get that with out a shrinkYou can't possibly think that 1070 will match 980ti. There is no way NVidia would do that. Maybe it will match 980. But thats all you can get.
Not sure why people keep thinking this - its more common for the next generation x70 type card to match or beat the previous generation high end card than it is for it to be slower.
again the GTX 970 was slower than the GTX 780Ti at launch
https://www.techpowerup.com/reviews/MSI/GTX_970_Gaming/11.html
TPU launch day review....
