- 19 Oct 2006
Is anybody using the cloud key controller?
I'm still a bit confused. Are these wireless, or do they have to be plugged in via ethernet?
Both wired and wireless, acting as a bridge.
Great kit.
not being rude but what's special about them?
How do they work over WiFi? What sort of speed do you get?
In my house I'd like to improve the WiFi but running ethernet cables is not practical at the moment. Powerline isn't keeping up with my FTTC speeds anymore.
Excellent news! I know the feeling about wanting to buy one more "just 'cause"... =)Just a little feedback on this. I'm really happy with the Pro unit I bought. The range is fantastic. I don't need a second one. I'm a bit sad about this to be honest lol! Was looking forward to having a zoned setup. Might still do it when or if i finally clean out my garage. Or, I might stick one near the back of the house for better garden wifi. To be honest though, i'm just looking for a reason to buy a second one at this point
Wifi used to go up and down all the time in my house with an integrated router and access point (7 year old DIR-655 D-Link). Now, with just my VM SuperHub and this AP everything is absolutely rock solid.
Thanks for the tip off to get one of these guys.
These look/perform great and the UI looks splendid. I considered buying a pair inc the router and a Poe switch but then for me it's unnecessary cost and additional work required to route cables to the ceiling and re-plastering walls.
If I was starting from scratch I would defo go this route.
Really?
We have around 20 of them at work (mostly in a warehouse environment, for handheld barcode scanners), and they are faultless - no issues withe the zero hand off roaming.
300?! Are 'We' an entire country?We have just under 300 and they are also faultless!
300?! Are 'We' an entire country?![]()
AC Lite, AC LR, or AC Pro, these 3 are the recommended models everyone is using and loving.Which models still support zero handoff, need to purchase some soon.
/Edit: Preferably with AC functionality to be future proof...
