Remind me again, who does Tom work for and what is his job title, ah yes, he is the director of technical
marketing at nvidia...
Sure choice is good but I would rather they optimise G-Sync (which they do) and they know what each panel is tuned to for their GPUs. More doesn't always mean better. My ROG Swift allows G-Sync to work all the way down to 1fps (not that I would want to game at that framerate) and not sure there are any Adaptive Sync panels that can do this? Some of the Freesync monitors ranges are quite poor as well and with a tiny tiny window in which to allow Freesync to operate. Frames need to be capped as well via external software to keep you within the freesync range. It just starts adding so many variables, I would rather they concentrate and dictate to what panels get G-Sync modules so the consumer gets the best possible experience.
Except it has been proven by various "fair" tests from knowledgeable experts i.e. PCMonitors, TFTcentral, Anandtech etc. that their is no real noticeable difference between the 2 sync techs.
No.
They are both equally as effective at eliminating tearing, juddering and stuttering from the traditional refresh rate and frame rate mismatches. I've seen some fairly good pixel overdrive implementations for both FreeSync and G-SYNC models and also some not so good ones. And if there are any latency differences they're certainly beyond my sensitivity for that sort of thing.
The freesync range depends on the monitor used and either way, according to PCM2, it really doesn't matter since AMD have LFC now and as I have said many times before you really don't want to be hitting any lower than 40 fps max anyway, g/free sync is not a silver bullet like what many make it out to be.
Low frame rates are low frame rates regardless. You really don't want to be getting under 56fps or anywhere near that on a 144Hz monitor, it feels and looks extremely sluggish. And besides, now that AMD has LFC the frame rates below the hardware floor (56Hz/56fps) are suitably compensated for to remove stuttering and tearing. It's very much a non-issue really.
Before someone links the tomshardware article, they compared a freesync monitor with completely different sync range and back then AMD/freesync didn't have low frame rate compensation either.
Also, no you don't need external software to cap FPS, you can set a global FPS cap via AMD crimson, which goes from 30 to 200.
Generally more is better as it means that there is more competition thus more competitive prices, if you want gsync monitors, you are pretty limited to who you can choose and the only real players invested in gsync atm are ACER and ASUS who aren't exactly well regarded for their QC + CS and as shown by the acer + asus 27" 1440 144+HZ IPS panels, they are plagued with bleed and dead pixel issues so just because they have gsync does not mean that the customer is going to get a good quality unit "overall".
Either way, there is still no reason why nvidia can't do both.
