I'm a Remainer because cheap duty-paid ciggies![]()
why would we lose talent ? Would we not attract talent if we left the EU then ?
Yes but once you take away the funding for research which is essentially just to push agendas, the slice of the pie looks much bigger.
Buying some duty free fags, booze and perfume when I go on holiday is hardly comparable to having the whole EU trading block at my fingertips on the Internet where I can purchase any item I want duty free![]()
Pouring billions into (creating) a Black Hole ?
There are likely to be quite significant gains to our knowledge with this that should benefit mankind.
We are ALL already benefiting by its creation due to the WWW being invented for it.
Not to detract from the point that the LHC is a major benefit to mankind.
To my knowledge the WWW wasn't invented for the LHC.
The idea that we would become some little backwater incapable of dealing on the world stage if we leave the EU is ridiculous.
I generally know nothing about the funding about it ? , I won't Google it but am I missing something what's that got to do with my post ??
Science wise yeh its interesting , don't actively follow it tbh
but it will probably be hit by a ~2% to ~6% loss in growth which will probably be felt as brutally as the 2008 crash was felt.
I know you're very pro EU but considering we've lost our veto to further integration if we remain in the EU then how is it that we're going to realistically have influence on the way the EU works? Brexit has already had the EU flex there muscles and sideline us regardless of the outcome and you're being facetious or deceiptful to suggest otherwise. We've lost our biggest chance to actually have reform in the EU and gained very little, if we remain we lose our veto on integration and policy matters but if we leave we are sidelined somewhat too. I'll admit that as it's a risk and I'm not going to be as dishonest as you are being in that presentation of how the EU mechanisms will work in our favour.I'm not really sure how you think this is a response to the line from my post you're quoted above it. Yeah, we'll carry on having our currency and we'll carry on having some influence; that influence will be less than it would be if we stay within the EU and retain our influence over the other countries inside the EU via EU mechanisms and across the world as magnified by the EU.
This is the problem I have with some pro EU people, they basically harp on endlessly that others are missing the point while being head in the clouds themselves. I'm back to being undecided based on the fact I still question sovereignity issue and us losing our veto has only put us in a worse spot with the EU. It's funny that every positive about the EU is marred by a negative just like that too.It wasn't invented for the lHC specifically but for projects like the LHC at CERN who developed the LHC.
Did you just make that up?
Yes you did.
Did I?
Even setting aside foreign investment, migration and the dynamic consequences of reduced trade, we estimate the effects of Brexit on trade and the UK’s contribution to the EU budget would be equivalent to a fall in income of between 1.3% and 2.6%. And once we include the long-run effects of Brexit on productivity, the decline in income increases to between 6.3% and 9.5%.
http://voxeu.org/article/economic-consequences-brexit
Static losses due to lower trade with the EU would reduce UK GDP by between 1.1% in an optimistic scenario and 3.1% in a pessimistic one. The losses due to lower FDI, less skilled immigration, and the dynamic consequences of reduced trade could also be substantial.
http://cep.lse.ac.uk/pubs/download/EA022.pdf
A final myth, that the mere existence of our group should debunk, is that there are no economists or economic studies favouring Brexit. Many important studies, from the mayor of London’s economics team, Capital Economics, Open Europe, the Centre for Economics and Business Research and the IEA, have suggested that there would be no long-term material losses from Brexit, and in some cases gains. Well-known figures, such as former Bank of England governor Lord (Mervyn) King, have said that our leaving the EU is not primarily an economic question, with the impact of leaving greatly exaggerated.
After all if we leave we do still get to rejoin the EFTA and have a say in the decision shaping process so without veto on the way the EU operates and still some say if we leave it seems there's not much to be gained by staying (at least in the poltiical change argument).
If the referendum represented our best chance get reforms from the EU in our favour then how can you believe the next 40 years will look positive given the results![]()
I do not know how CERN and LHC got involved with the EU debate as they have nothing to do with the EU except that some of the countries on the CERN committee are also within the EU, some are not. The funding is by country, not by the EU.
Anyway it is a good collaborative example of research between nation states and one that should and would be continued with the UK in or out of the EU.
CERN's main function is to provide the particle accelerators and other infrastructure needed for high-energy physics research – as a result, numerous experiments have been constructed at CERN as a result of international collaborations.
CERN is also the birthplace of the World Wide Web (not the internet which is something else). The main site at Meyrin has a large computer facility containing powerful data processing facilities, primarily for experimental-data analysis; because of the need to make these facilities available to researchers elsewhere, it has historically been a major wide area network hub.
Your first link is to an organisation that gets funding from the EU commission.
Your second link is one academic report. Yes it's by some fancy economists, but i'd question why they assumed less skilled immigration, the central Brexit case is an Australian based points system where we continue to welcome people with skills the country needs.
Here are some other economists views.
Here are 100 business figures saying the city would thrive if we left. EU trade deals don't cater very well for services, a lot of them make no mention of services at all. We're already predominantly services focused, and will be even more so in the future.
The Institute of Economic Affairs has estimated the benefits to Britain of new trade deals under Brexit here. We can't negotiate our own deals with the parts of the world that are growing the fastest, we leave that to the EU. The EU has been negotiating on our behalf badly, and a lot of deals or are on hold because of disputes about Italian tomatoes or Romanian Visas, as well as being goods focused as above.
Then there are other economic cases for Brexit, here:
) to 100% Brexiteer.
As with most things, there are arguments on both sides.
I'd encourage anyone on the fence to try and figure out how the EU actually works. Not what it's supposed to be, or represent, but what it is in reality and how it actually works. Searching Youtube for "eu documentary" is a good start.
