- 25 Apr 2009
- Sidcup
Looks epic
Did you get my email by the way?
Looks epicDid you get my email by the way?
Looks lush. What sort of clean was that?![]()
My 996 is having issues with the idling as it keeps stalling when hot with no lights on dash. Annoying as struggles to restart but fires up with a little accelerator.
Sounds impressive stuff, is that what's referred to as a ceramic coating? Or is that a different G tech product I'm thinking of?
Yes, I have had a few of my cars done in the past but this time I spent a bit more and got it don't by a very good detailer.
Next Monday is D-day.
Getting local garage to fit new Pagid discs (using Pagid Cera-tec to their amusement lol) and pads. Not sure whether to use old bolts or fit new ones as have them? Depends on condition I guess.
Also going to change oil and filter for mann filter and Miller Nanodrive CFS 10w50 NT.
How much oil does it hold though? I've seen 8.25 litres? But then maybe 8.75 litres?
Will also look into fitting Beru spark plugs and Mann air and pollen filters. Spark plug gap is supposed to be 1.6mm? 1999 C2 Tiptronic.
Anyone know where you can order a manual from?
Like a Haynes manual where it contains all the torques settings. I've seen here: http://www.emanualonline.com/advanc...in_description=1&keywords=porsche+996&x=0&y=0 Has anyone used them??
Thank you Vince!
Drop me a message on the other site and i'll buy you a beer mate!
