I have a clay mitt, a clay bar, isopropyl alcohol, Autoglym Fast Glass, Glass polish. That windscreen will be cleaner than a surgical knife before I put it on![]()
not too impressed with AG clean wheels tbh!seems to struggle to get the brake dust off my white wheels! sonax worked way better.
what other wheel cleaners do you guys recommend?
What air fresheners are people finding the best to spray into upholstery of their cars? I've been using Chemical Guy's Stripper Scent for a while but I find the smell only lasts a day or two before it's gone...do people know of any better longer lasting sprays?
I need to get some - just waiting for my aqua wax to run out.
These arrived the other day. The BSD is thick, I think it might be thicker than full fat milk.
