The founders edition is just the reference card, so far there seems to be no difference between the one nvidia sell and the aib's. Nvidias is priced higher so not to **** off their partners.
I know.
Does the NDA lift ay 00:00:01 UK time or USA?
All that info is under NDA, just have to wait to see.
Even this info that is under NDA is under NDA and Gerard is breaching it...automatically delaying the release to UK for a month
Gives the first day buyers time to stock up on lube!
haha! I'm waiting for the AIB releases, Then i will sell it when the Ti is released then and lose £40 - £50.
If you are happy to lose £50 every 6 months on gpu hardware its easy to have the latest gpu on release date, its when you miss a generation you lose too much money.
seen some 980 ti g1's go for as little as £350
this will change once the new cards are released then the 2nd hand price will increase ...
im wondering if its just best to Keep buying the "mid" ranged card from a pure perf/time/cost perspective
what i mean is buy
780 on release, cheaper than a Ti generally, skip ti
buy
980 on release cheaper than Ti generally skip Ti
buy
1080 on release cheaper than Ti generally skip Ti
i wonder if that actaully works out cheaper & better perf over time?
you get new tech quicker, cheaper unless of course you start at Ti.
Yes its crazy at the moment on fleabay
the site is flooded with 900's seen some 980 ti g1's go for as little as £350
this will change once the new cards are released then the 2nd hand price will increase ...but this all depends what the release price of the 1080 but i am certain they will be over £550 at least ...
But you never know
one things for sure this is the prime time to pick up last gen cheap very cheap.
I would tell you but I'm under NDA.so if the NDA end date has an NDA
that NDA must have an end date ?
if that is under NDA ? then ......
where does it end lol
Why would you pay more than £350 for a 980ti when Nvidia "claim" that the 1070 will be faster than a Titan.
Ergh at least 3 weeks on a 5870, this sucks.
You wouldn't. If the 1070 is faster than the Titan X, used 980Ti prices will have to go near the £250 mark.
